Visual LISP, AutoLISP and General Customization
Hight Label LISP
23 REPLIES 23
Message 1 of 24
Klingi162
1021 Views, 23 Replies
Hight Label LISP
Hey guys,
I'm trying to set up a hight label for sections and elevations. I then want to update it with a shortcut.
I already tried it with a field that shows me the y coordinates, but it won't show me the "+-"0.00 sign,when I put it to zero level. It only writes "0.00".
So I guess I have to ork with attributes. Any solutions how I can manage that?
cheers
23 REPLIES 23
Message 21 of 24
Klingi162
in reply to: hmsilva
hey, me again. 😉
I now tried to make the heightlabel to a dynamic block with a dropdownlist for different visibilities. Now it won't update anymore...
doesn't this work for this kind of scripts? I added the block to show you what I mean. Maybe you got a clue how to work with such blocks...
Message 22 of 24
hmsilva
in reply to: Klingi162
Hi klingi,
sorry for the late reply, but I didn't see your post Smiley Embarassed
The code wasn't tested (I don't have AutoCAD in this pc), assuming that there is only one attribute in your block, you'll have to change the dynamic block name to the correct one (I left the old name)...
(defun c:test ( / *error* ATT ENT HND ITM NUM OLD_ZIN PT S1 TXT Y)
  (defun *error* ( msg )
  (if Old_zin (setvar 'DIMZIN Old_zin))
  (if (not (member msg '("Function cancelled" "quit / exit abort")))
    (princ (strcat "\nError: " msg)))
  (princ)
  (if (setq s1 (ssget "_:L" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," "__Hoehenkote")) '(66 . 1) (cons 410 (getvar 'CTAB)))))
    (progn
      (setq Old_zin (getvar 'DIMZIN))
      (setvar 'DIMZIN 0)
      (setq itm 0 num (sslength s1))
      (while (< itm num)
      (setq hnd	(ssname s1 itm))
	(if (eq	(vla-get-effectivename (vlax-ename->vla-object hnd)) "__Hoehenkote")
	  (progn
	    (setq ent (entget hnd)
		  att (entget (entnext hnd))
		  pt  (trans (cdr (assoc 10 ent)) 0 1)
		  y   (/ (cadr pt) 100.0))
	    (cond ((> y 0.0)
		   (setq txt (strcat "+" (rtos y 2 2)))
		  ((= y 0.0)
		   (setq txt (strcat "±" (rtos y 2 2)))
		  (T (setq txt (rtos y 2 2)))
	    );; cond
	    (entmod (subst (cons 1 txt) (assoc 1 att) att))
	  );; progn
	);; if
	(setq itm (1+ itm))
	);; while
      );; progn
    );; if
  (princ)
  );; test
Try it, and let me know if it works as expected.
Hope that helps
Henrique
Message 23 of 24
Klingi162
Hey henrique,
works great. Now it can do every trick! Thanks again
cheers Klingi
Message 24 of 24
hmsilva
You're welcome, klingi
Henrique
”Boost
