Visual LISP, AutoLISP and General Customization
Help with tlindell code
0 REPLIES 0
Message 1 of 1
rapidcad
216 Views, 0 Replies
Hi all, I’m trying to modify some code that tlindell posted. The original code was written
to check dynamic block parameter and attribute prompts upon insertion. It
prompts the user for every attribute and parameter value and then modifies the
block through reactors. I found this through doing a search for code that might
be useful to insert dynamic blocks while setting their parameter values from
lisp variables I would want to pre-set via a dialog box or settings file or a
combination of both. My lisp is rusty, and my vlisp knowledge is very limited,
so I am challenged to just figure out the program and try to see which parts to
keep, and what to ditch for my purposes.
So far I’ve commented a copy of it so I can try to keep track of what I think I
see going on. I am in the process of deciding where to go with this from here..
Can anyone lend me their experience with this?
Any help greatly appreciated! (esp. from tlindell since he is the original author)
(I reposted this to upload the right lisp file)
ADN CAD Developer/Operator
0 REPLIES 0
”Boost
