I don't have that command available to test, but if it works like most others, you should be able to
put pauses in for User input, with the word 'pause.' You should also be able to put it all into one
(command) function. You'll have to confirm the sequence of prompts, but maybe something like this:
{code}
(command
"LabelCurveOffsetNode"
pause ; for User selection, presumably with the command's own prompt
"Y"
"0.1"
pause ; for User selection of offset side, if that's the way it works
"" ; finish the command
); end Lisp command function
{code}
Kent Cooper
timsea wrote...
I'm trying to write a lisp program for MEP to offset a label on a duct, allowing the label then to
be moved around with the grips. It should be pretty simple, just a handful of commands to be entered
at the command line. What the lisp should do is automate the following process: 1- type
LabelCurveOffsetNode at the command line 2- the LabelCurveOffsetNode will ask the user to select a
label to be offset 3- type 'y' at the command line in response to whether to offset one at a time 4-
type '0.1' at the command line to give it an insignificantly small offset, after which it can be
moved with the grip Step 2 is what I don't know how to do. What I have now is this: (defun
C:labeloffset() (command "LabelCurveOffsetNode") (command "Y") (command "0.1") (command "") (princ
"\nYOU MAY NOW MOVE THE LABEL WHEREVER YOU WANT") (princ) ) But this does not stop for the
LabelCurveOffsetNode to prompt to select a label. I need a way to pause my lisp, allow the user to
enter information in accordance with the LabelCurveOffsetNode command, then start back up again for
the remaining steps. I'd think this should be pretty simple, but I don't really know what I'm doing.
Any help is appreciated! Thanks!
