hi all,
i've been trying to create a macro that will stramline a repetetive command but I'm lost and confused.
i have single lines ( a whole lot of them) along roadways that i need to convert to double lines with a certain width (.8). I have (what i think is) a lisp routine (a .fas file) that someone provided that changes the line to a double line....but what i need is to tell it to use the same width each time. so that it will go faster. and if it had the MULTIPLE option, that would be even better.
is all of this wishful thinking on my part?
Solved by Kent1Cooper. Go to Solution.
This ?
(defun c:Test (/ ss i o) (if (setq ss (ssget "_:L" '((0 . "LINE")))) (repeat (setq i (sslength ss)) (setq o (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (foreach x (list 0.8 -0.8) (vla-offset o x) ) ) ) (princ) )(vl-load-com)
@cadman33619 wrote:
i have single lines ( a whole lot of them) along roadways that i need to convert to double lines with a certain width (.8). ....
If you want the double line centered around the original, you can use the attached OffsetBothSides.lsp with its OBS command. In your example case, give it .4 [half the desired spacing] for the offset distance. You can select as many things [of any Offsettable type) as you want to double-offset that way, in one running of the command, and it remembers your distance and offers it as the default when you use the command again in the same drawing session.
It currently leaves the original middle object in place, but if you want that removed, that would be an easy adjustment.
Kent...
i would need the original line removed. Can you do that for me?
I have no experience at all dealing with writing/creating lisp commands. I'm still trying to figure out how to apply/use the code provided by Tharwat....i suppose I should have just asked him.
A quickie alteration of the other one, into an OffsetBothSidesErase.lsp file with its OBSE command....
and thank you to Tharwat for the info.... You've inspired me to learn more about how that works.
@cadman33619 wrote:and thank you to Tharwat for the info.... You've inspired me to learn more about how that works.
Happy to hear that , and do not hesitate to ask if you have any question .
Regards.
Tharwat
out of curiosity, Kent... would it be possible to add the WINDOW option to that? ie... if i have lots of them..i can isolate that layer then start the command then window all of them... and get them all done at once?
not trying to be greedy here... what you provided is already a HUGE time-saver. just thought that would be nice.
@cadman33619 wrote:
.... would it be possible to add the WINDOW option to that? ie... if i have lots of them..i can isolate that layer then start the command then window all of them... and get them all done at once?
Not difficult [not just the Window option, but any selection method(s)], but not today.... Watch this space.
@Kent1Cooper wrote:
@cadman33619 wrote:
.... would it be possible to add the WINDOW option to that? .....
Give this a shot.
In testing, I find that for some reason it doesn't like to work with Rays. [It seems to work for everything else.] It also seems to be true of the original OBS command that doesn't delete the selected thing in the middle [I must not have tested it thoroughly enough back then...]. Rays are perhaps a comparatively rare thing, and that may not be an issue for you, but if others have any idea why that should be, I'd be interested in theories. It's on my old version here, and I'll try it on 2015 when I get to it, in case it's version-specific, so I'd also be interested in whether it works for some versions. Or is there just some kind of incompatibility with (vla-offset) and the Ray object type?
