I have found a lisp routine that can extract the block quantites in a drawing which puts the values into a legend including a symbol. The lisp routine is below:
i am looking for a solution to add an additional routine that will include the attribute information in the same table.
Please help.
(defun c:BlkQty (/ blk_id blk_len blk_name blks ent h header_lsp height i j TOTAL
len0 lst_blk msp pt row ss str tblobj width width1 width2 x y
;; By : Gia Bach, gia_bach @ www.CadViet.com ;;
(vl-load-com)
(defun TxtWidth (val h msp / txt minp maxp)
(setq txt (vla-AddText msp val (vlax-3d-point '(0 0 0)) h))
(vla-getBoundingBox txt 'minp 'maxp )
(vla-Erase txt)
(-(car(vlax-safearray->list maxp))(car(vlax-safearray->list minp))) ) (defun GetOrCreateTableStyle (tbl_name / name namelst objtblsty objtblstydic tablst txtsty)
(setq objTblStyDic (vla-item (vla-get-dictionaries *adoc) "ACAD_TABLESTYLE") )
(foreach itm (vlax-for itm objTblStyDic
(setq tabLst (append tabLst (list itm))))
(if (not
(vl-catch-all-error-p
(setq name (vl-catch-all-apply 'vla-get-Name (list itm)))))
(setq nameLst (append nameLst (list name))) ) )
(if (not (vl-position tbl_name nameLst))
(vla-addobject objTblStyDic tbl_name "AcDbTableStyle"))
(setq objTblSty (vla-item objTblStyDic tbl_name)
TxtSty (variant-value (vla-getvariable *adoc "TextStyle")))
(mapcar '(lambda (x)(vla-settextstyle objTblSty x TxtSty))
(list acTitleRow acHeaderRow acDataRow) )
(vla-setvariable *adoc "CTableStyle" tbl_name) ) (defun GetObjectID (obj)
(if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
(vlax-invoke-method *util 'GetObjectIdString obj :vlax-false )
(vla-get-Objectid obj)))
;main
(if (setq ss (ssget (list (cons 0 "INSERT"))))
(progn
(vl-load-com)
(setq i -1 len0 😎
(while (setq ent (ssname ss (setq i (1+ i))))
(setq blk_name (cdr (assoc 2 (entget ent))))
(if (> (setq blk_len (strlen blk_name)) len0)
(setq str blk_name len0 blk_len) )
(if (not (assoc blk_name lst_blk))
(setq lst_blk (cons (cons blk_name 1) lst_blk))
(setq lst_blk (subst (cons blk_name (1+ (cdr (assoc blk_name lst_blk))))
(assoc blk_name lst_blk) lst_blk))) )
(setq lst_blk (vl-sort lst_blk '(lambda (x y) (< (car x) (car y)) ) ))
(SETQ TOTAL 0)
(FOREACH I LST_BLK (SETQ TOTAL (+ TOTAL (CDR I))))
(or *h* (setq *h* (* (getvar "dimtxt")(getvar "dimscale"))))
(initget 6)
(setq h (getreal (strcat "\nText Height <" (rtos *h*) "> :")))
(if h (setq *h* h) (setq h *h*) )
(or *adoc (setq *adoc (vla-get-ActiveDocument (vlax-get-acad-object))))
(setq msp (vla-get-modelspace *adoc)
*util (vla-get-Utility *adoc)
blks (vla-get-blocks *adoc))
(setq width1 (* 4 (TxtWidth " " h msp))
width (* 2 (TxtWidth "Text Height" h msp))
height (* 2 h))
(if str
(setq width2 (* 1.5 (TxtWidth (strcase str) h msp)))
(setq width2 width))
(if (> h 3)
(setq width (* (fix (/ width 8))8)
width1 (* (fix (/ width1 8))8)
width2 (* (fix (/ width2 8))8)
height (* (fix (/ height 5))5)))
(GetOrCreateTableStyle "CadEng")
(setq pt (getpoint "\nPlace Table :")
TblObj (vla-addtable msp (vlax-3d-point pt) (+ (length lst_blk) 3) 4 height width));CHANGE 5 TO 4
(vla-put-regeneratetablesuppressed TblObj :vlax-true)
(vla-SetColumnWidth TblObj 0 width1)
(vla-SetColumnWidth TblObj 1 width2)
(vla-put-vertcellmargin TblObj (* 0.75 h))
(vla-put-horzcellmargin TblObj (* 0.75 h))
(mapcar '(lambda (x)(vla-setTextHeight TblObj x h))
(mapcar '(lambda (x)(vla-setAlignment TblObj x 8))
(list acTitleRow acHeaderRow acDataRow))
(vla-MergeCells TblObj 0 0 0 3);change 4 to 3
(vla-setText TblObj 0 0 "Block Count Table")
(setq j -1 header_lsp (list " " "Block Name" "Quantity" "Preview"));;;;;;;;;;;;;;;;;;;;;;REMOVE "DON VI"
(repeat (length header_lsp)
(vla-setText TblObj 1 (setq j (1+ j)) (nth j header_lsp)))
(setq row 2 i 1)
(foreach pt lst_blk
(setq blk_name (car pt) j -1)
(mapcar '(lambda (x)(vla-setText TblObj row (setq j (1+ j)) x))
(list i blk_name (cdr pt)));;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;REMOVE "CAI"
(vla-SetBlockTableRecordId TblObj row 3 (GetObjectID (vla-item blks blk_name)) :vlax-true);CHANGE 4 TO 3
(vla-SetCellAlignment TblObj row 1 7)
(vla-SetCellAlignment TblObj row 2 9);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;CHANGE 3 TO 2
(setq row (1+ row) i (1+ i)) )
(VLA-SETTEXT TBLOBJ ROW 1 "TOTAL")
(VLA-SETTEXT TBLOBJ ROW 2 TOTAL)
(vla-put-regeneratetablesuppressed TblObj :vlax-false)
(vlax-release-object TblObj) ) )
(princ))
