Visual LISP, AutoLISP and General Customization
Help with LISP coding...
1 REPLY 1
294 Views, 1 Reply
Hi,  I have found this attached .lsp file to draw lines at a certain bearing and distance... It works well, except that it will not register the seconds that I am inputting... For instance, in the "COLB" routine, which is what I use 99% of the time, typing the bearing 10.1010 results in a line being drawn at 10.1000.  Any help would be greatly appreciated!  Thanks,
1 REPLY 1
stevesfr
set LUPREC in acad to 4 and you're good to go.
HTH
Steve
”Boost
