Visual LISP, AutoLISP and General Customization
Help with exporting point locations to text file
25 REPLIES 25
Message 1 of 26
Cadastrophe1911
4313 Views, 25 Replies
Hi all... Im trying to come up with a lisp that will export x and y coords to a txt or cvs file. However, I need the lisp to export in this format
Units       Inch
WPT      1     0     0     ( X=0 Y=0)
WPT      2     1     1     (X=1  Y=1)
WPT      3     2     2
I need to be able to set my zero with move origin and the export the points.
This is for a post for a CNC Hole Popper
25 REPLIES 25
Message 21 of 26
@Cadastrophe1911 wrote:
Why am i getting this error
Command: drill20
; error: bad argument type: 2D/3D point: "29.31"
Sorry about that -- the (trans) should be applied to the point before extracing coordinates, not to the extracted coordinates.  Change this:
      (trans (rtos (car x) 2 4) 0 1) "\t" ; X coordinate <--- edit precision
      (trans (rtos (cadr x) 2 4) 0 1); Y coordinate <--- edit precision
to this:
      (rtos (car (trans x 0 1)) 2 4) "\t" ; X coordinate
      (rtos (cadr (trans x 0 1)) 2 4); Y coordinate
Kent Cooper, AIA
Message 22 of 26
(defun C:drill20 (/ ptfile inc ptlist);
  (setq
  ptfile (open "C:/TEMP/PTFILE.TXT" "w"); <---- edit file path & name
  inc 0
  ptlist
    (mapcar
      '(lambda (x) (cdr (assoc 10 (entget x)))); Point locations
      (mapcar 'cadr (ssnamex (ssget "_X" '((0 . "POINT"))))); all Point entities in drawing
    ); mapcar & ptlist
); setq
(write-line "Units\tInch" ptfile)
(foreach x ptlist
  (write-line
    (strcat
      "WPT\t"
      (itoa (setq inc (1+ inc))) "\t"
    ); strcat
    ptfile
(princ))
  (close ptfile)
); end defun
That works.. do i have my PRINC in the right place and format???? it still gives the nil
Message 23 of 26
    (mapcar
(princ))
  (close ptfile)
); end defun
The (princ) should be the last thing before the final closing right parenthesis.
It also occurred to me that it could be streamlined just slightly by translating each point's location from World to Current CS only once, instead of separately for each of the X & Y coordinates.  Try this:
  (setq
    inc 0
    ptlist
    (mapcar
      '(lambda (x) (trans (cdr (assoc 10 (entget x))) 0 1)); locations translated to current CS
    ); end mapcar & ptlist
  ); end setq
  (foreach x ptlist
    (write-line
      (strcat
        "WPT\t" ; WPT + tab
        (itoa (setq inc (1+ inc))) "\t" ; sequence number + tab
        (rtos (car x) 2 4) "\t" ; X coordinate + tab
        (rtos (cadr x) 2 4); Y coordinate
      ); end strcat
      ptfile
    ); end write-line
  ); end foreach
  (close ptfile)
  (princ)
); end defun
Kent Cooper, AIA
Message 24 of 26
Works Great...Smiley Very Happy thanks
Message 25 of 26
Works Great... thanks
You're welcome.  I also learned something I didn't know from this exercise:  it probably wouldn't even have occurred to me to wonder before whether the code for a Tab character in a text string in a .DWG file would translate correctly into a Tab in a .TXT file.  So I had to try it out, and now I know that it does [though whether I'll ever have further use for that information is another question...].
Kent Cooper, AIA
Message 26 of 26
mihai_bantas
in reply to: Kent1Cooper
Hello ,
What do i want to ask ... can you change the code in this way, without numbering WPT 1,2,3...
MYTEXT A, 1.00, 2.00, MYTEXT Z    ( where X =1.00 and Y=2.00, are coordinates of selected point)
MYTEXT NEW, 4.00, 5.00, MYTEXT OLD
MYTEXT RED, 6.00, 8.00, MYTEXT GREEN
MYTEXT GOOD, 10.00, 12.00, MYTEXT BAD
I HAVE TO SELECT MANUAL ONLY FOUR POINTS.....BUT MUST ADD MY VALUES (in the selected order of points) BEFORE AND AFTER THE COORDINATE OF THE SELECTED POINT.
Thank you in advance for the time spent on this problem that has been giving me headaches for some time.
”Boost
