Recently we tried adding layer lineweight to our DXF 2000 export. The original programmer is no longer working with us, and this is my first time working with DXF so stupid questions may be asked.
We are exporting layers and everything seems to be working fine when we import it into Autocad 2015, except the layer lineweight, which always gets set on Default, instead of a value.
I'll post what we get when we export
TABLE 2 LAYER 5 A61483 100 AcDbSymbolTable 70 2 0 LAYER 5 A61441 100 AcDbSymbolTableRecord 100 AcDbLayerTableRecord 2 0 70 0 62 7 6 CONTINUOUS 370 18 0 LAYER 5 A61475 100 AcDbSymbolTableRecord 100 AcDbLayerTableRecord 2 Plankopf 70 0 62 7 6 CONTINUOUS 370 18 0 ENDTAB
I've tried exporting the same thing from autocad, and compare the results. I've copy-pasted parts of the DXF file, mainly up the chain of dependencies codes 330 and 390, but it still would not work. If i went far enough, it wouldn't even load anymore.
Any ideas?
Thanks a lot
Solved by Gary_J_Orr. Go to Solution.
