Help with a routine
4 REPLIES 4
msarqui
247 Views, 4 Replies
Help with a routine
Hello!
I am trying to select objects with a window selection. After this, bring to front all Mtexts, and send to back all Dimensions.
Any help?
(defun c:test (/ sel1)
(princ "\nSelect a Mtext or Dimension")
(setq sel1 (ssget))
 (cond
     ((= sel1 "DIMENSION"); If Dimension
     (command "draworder" sel1 "" "b"); send it to back
     );eq
     ((= sel1 "MTEXT"); If Mtext
     (command "draworder" sel1 "" "f"); bring to front
     );eq
 ); cond
); defun
4 REPLIES 4
_Tharwat
in reply to: msarqui
Try this ...
(defun c:Test (/ ss)
(princ "\nSelect Mtexts and Dimensions")
  (if (setq ss (ssget "_:L" '((0 . "MTEXT,*DIMENSION"))))
    ((lambda (i / sn )
       (while (setq sn (ssname ss (setq i (1+ i))))
         (if (= (cdr (assoc 0 (entget sn))) "MTEXT")
           (command "draworder" sn "" "f")
           (command "draworder" sn "" "b")
       ) -1 )
  (princ)
hmsilva
Another
(defun c:Demo (/ ss ssD ssM)
  (prompt "\nSelect Mtexts and Dimensions")
    (progn
      (setq ssM (ssget "_P" '((0 . "MTEXT"))))
      (command "_.select" ss "")
      (setq ssD (ssget "_P" '((0 . "*DIMENSION"))))
      (if ssM
	(command "_.draworder" ssM "" "_F")
      (if ssD
	(command "_.draworder" ssD "" "_B")
  (princ)
HTH
Henrique
msarqui
in reply to: hmsilva
Many thanks to both of you.
The two answers are realy good. I will accept Henrique's answer as a solution because the two separate "If". It suits better for my purposes. Kudos to Tharwat
hmsilva
You're welcome, msarqui
Glad I could help
Henrique
”Boost
