Distinguished Contributor
Tom_Berning
Message 1 of 2 (152 Views)
Help to get routine to work in 2013
152 Views, 1 Replies
10-16-2012 02:32 PM
I don't do a lot of programming and when I do it is mostly with older lisp commands. I have routine that works in 2010 but we are switching to 2013 and it doesn't work. The routine assigns the area of a polyline to a field. The portion of the routine that isn't working is where it assigns the object id for the polyline. Here is that portion of the routine:
;; select an object
 (if (setq ent (entsel))
   (progn
     (setq ent (car ent))
;; Check to see if object selected is a polyline
     (if (= (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
       (progn
;; obtain the object id from the selected entity
         (setq objID (vla-get-objectid (vlax-ename->vla-object ent)))
Any help would be appreciated
Tom Berning
Woolpert, Inc.
Civil 3D 2013
(setq objID
(if (> (vl-string-search "x64" (getvar "platform")) 0)
(vlax-invoke-method (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)))
"GetObjectIdString" (vlax-ename->vla-object ent) :vlax-False)
(itoa (vla-get-Objectid (vlax-ename->vla-object ent)))
HTH
pbejse
Message 2 of 2 (134 Views)
Re: Help to get routine to work in 2013
10-16-2012 06:41 PM in reply to: Tom_Berning
(setq objID
HTH
