Help to code this lisp
5 REPLIES 5
asos2000
448 Views, 5 Replies
I want to code this lisp. So can some help me just the steps and commands i'll do the rest
The problem which I face is, In some drawings which come from the client, there are a lot of blocks.
I want to detect the blocks which has no sub-entities (but attribute) and add a rectangle inside this block, If it is an attribute add a line from 0,0, to insertpoint of attribute.
5 REPLIES 5
hmsilva
in reply to: asos2000
asos2000,
try
(defun c:test ()
  (if (setq ss (ssget "_X" '((0 . "INSERT")))) ; select all blocks
    (progn
      (setq itm	0 num (sslength ss))
      (while (< itm num)
	(setq hnd (ssname ss itm)
      	      ent (entget hnd))
	(IF (= (cdr (assoc 66 ent)) 1); if Attrib
	  (command "line" "_non" "0,0,0" "_non"  (cdr (assoc 10 ent)) ""); draw line
	  (progn; if not Attrib
	    (vla-getboundingbox (vlax-ename->vla-object hnd) 'minpoint 'maxpoint); get boundingbox
	    (setq pt_lst (list (vlax-safearray->list minpoint) (vlax-safearray->list maxpoint))); get points in list
	    (command "rectangle" "_non" (car pt_lst) "_non" (cadr pt_lst)); draw Rectangle
	  ); progn
	); if
	(setq itm (1+ itm))
      ); while
    );progn
  ); if
); test
 Cheers
Henrique
asos2000
in reply to: hmsilva
Thanks hmsilva for your quick reply
PLease find attached a file has sa sample of 2 blocks
one has no objects this blocks i want to draw a rectangle inside - (lets say 1000x1000)
another one has attribute only
If no objects draw a rectangle inside the block
if att only draw a line from 0,0 of the block to inspoint of any att inside the block too
Regards
Kent1Cooper
Some questions:
In your sample drawing, it appears you want the Line, drawn from 0,0 to an Attribute insertion point, to become a part of the Block definition.  It looks like hmsilva's routine would not do that, but would draw the Line independent of the Block.  Does it matter which way that is done?  [Independent is certainly easier.]
It's hard to imagine what a rectangle "inside" a Block with no sub-entities would be like -- should it be, for example, centered around the Block's insertion point [and therefore actually "outside" it]?  Drawing it around the bounding box as in hmsilva's routine would, I think, result in a zero-extent rectangle if the Block has no sub-entities [visually, a point, but not one that can be made easier to find with a PDMODE setting].  And should the rectangle become a part of the Block definition, or can it be independent?  If it's part of the definition, it will make multiple such Blocks visible, but maybe you never have more than one.
It also looks as though hmsilva's routine would draw a Line to the insertion point of the Block itself, rather than to the insertion point of an Attribute in the Block.  And it looks as though it would draw a Line from 0,0 to the insertion point of any Block containing Attributes, whether or not it also contains any other sub-entities, and would draw a rectangle around the bounding box of any Block without Attributes, whether or not it contains anything else.  I don't think those are what you're asking for, but a confirmation would be helpful.
Kent Cooper, AIA
dgorsman
A basic, but non-code dependant, solution: ATTDISP command.
Out of curiosity... AF/AF-BASE, AO/AO-BASE, and/or VAL_BLK blocks?
asos2000
in reply to: dgorsman
Try this code
(defun c:revealblocks ( / doc lst )
;;  Author: Lee Mac, - www.lee-mac.com       ;;
    (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
        (if
            (and
                (= :vlax-false (vla-get-islayout blk))
                (= :vlax-false (vla-get-isxref blk))
                (null (wcmatch (vla-get-name blk) "`**"))
            (progn
                (setq lst nil)
                (vlax-for obj blk (setq lst (cons obj lst)))
                (cond
                    (   (null lst)
                        (vla-put-closed
                            (vlax-invoke blk 'addlightweightpolyline
                               '(0.0 0.0 1000.0 0.0 1000.0 1000.0 0.0 1000.0)
                            :vlax-true
                    (   (vl-every '(lambda ( x ) (= "AcDbAttributeDefinition" (vla-get-objectname x))) lst)
                        (foreach att lst
                            (vlax-invoke blk 'addline '(0.0 0.0 0.0) (vlax-get att 'insertionpoint))
    (vla-regen doc acallviewports)
    (princ)
(vl-load-com) (princ)
”Boost
