Visual LISP, AutoLISP and General Customization
Help: Saving and Loading vla-objects
4 REPLIES 4
190 Views, 4 Replies
I try to save a list of vla-objects in a file.
When I load this list the vla-objects are destroyed.
Example:
The list entry of a vla-object before saving the data.
[0] #<VLA-OBJECT  IACADLWPOLYLINE   02F99E94>
This object is recognized as a vla-object.
The list entrys of a vla-object after loading the data.
[0] #<VLA-OBJECT
[1] IACADLWPOLYLINE
[2] 02F99E94>
The three Listentrys are recognized as Symbols.
Saving the list with LISP Datatypes works fine, but not with vla-objects.
Any idea ?
4 REPLIES 4
A VLA-object is a COM wrapper around an AutoCAD entity. Your handle to
this wrapper is nothing more than a pointer, a memory address. That
address will not point to the same data between instances of AutoCAD
as it allocated dynamically.
On the other hand, an entity handle as returned by AutoLISP is
permanent and will always represent the same object within a given
drawing file (assuming the object still exists at the time you use the
handle).
"That's no ordinary rabbit."
http://www.acadx.com
"Matthias Senff" wrote in message
news:3BB96C94.994C9C66@weisstalwerk.de...
Example:
[0] #
[0] #
[1] IACADLWPOLYLINE
[2] 02F99E94>
vla-objects.
Any idea ?
What exactly is meant by "wrapper". I have always thought of a vla-object
as "the" object itself, hence, the release-object woes of RRB and others.
Cliff
"Frank Oquendo" wrote in message
news:D3AB765D6D6CC9A8E2865D9CEE4A4AD2@in.WebX.maYIadrTaRb...
| handle).
| Hello,
| Example:
| [0] #
| [0] #
| [1] IACADLWPOLYLINE
| [2] 02F99E94>
| vla-objects.
| Any idea ?
Cliff, come over to the dark side and these mysterious objects and terms
become very apparent. The dark side is very powerful and can open up
entirely new worlds to you 🙂 It takes no more than creating your first
class module to understand what is meant by 'wrapper'. For now I'm going to
defer to Frank for a complete explanation because he is definitely darker
than I 🙂
Bobby C. Jones
Dots & Parens living in harmony...
| Cliff, come over to the dark side...
NO! You can't be my father!
”Boost
