Visual LISP, AutoLISP and General Customization
HELP PLEASE
6 REPLIES 6
agent47x
287 Views, 6 Replies
HELP PLEASE
command: hole
Specify radius <2.0>:
Pick point:
Next point:
(setq sd (getreal (strcat "\nSpecify Radius <"(rtos $sd 2 1)">: ")))
how to put that in this hole.lsp
(defun c:HOLE(/ circle_2 pt1)
(if (setq pt1 (getpoint "\nSelect Pick Point: "))
(progn (command "circle" pt1 sd)
(setq circle_2 (entlast))
(load "extrim")
(acet-error-init (list
(list "cmdecho" 0
"highlight" 0
"regenmode" 1
"osmode" 0
"ucsicon" 0
"offsetdist" 0
"attreq" 0
"plinewid" 0
"plinetype" 1
"gridmode" 0
"celtype" "CONTINUOUS"
"ucsfollow" 0
"limcheck" 0
T ;flag. True means use undo for error clean up.
'(if redraw_it (redraw na 4))
);list
);acet-error-init
(etrim circle_2 pt1)
(acet-error-restore)
(entdel circle_2)))
(princ)
6 REPLIES 6
hmsilva
in reply to: agent47x
Perhaps something like this
(defun c:HOLE(/ *error* circle_2 osm pt1)
  (defun *error* (msg)
    (if (not (member msg '("Function cancelled" "quit / exit abort")))
      (princ (strcat "\nError: " msg))
    (princ)
  (setq osm (getvar 'OSMODE))
  (load "extrim")
(list "cmdecho" 0
"highlight" 0
"regenmode" 1
"osmode" 0
"ucsicon" 0
"offsetdist" 0
"attreq" 0
"plinewid" 0
"plinetype" 1
"gridmode" 0
"ucsfollow" 0
"limcheck" 0
);list
);acet-error-init
(or $sd (setq $sd 2.0))
  (if (null sd)(setq sd $sd)(setq $sd sd))
(while (and (setvar 'OSMODE osm)
  (setvar 'OSMODE 0)
  );; while
(princ)
Hope that helps
Henrique
doni49
in reply to: hmsilva
agent,
I just thought I'd explain the HOW of including a default setting in the prompt (which is what you're looking to do and what Henrique has provided for you).
;This line sets $sd to a default value of
;2.0 if there's not one already set.
;Then display the prompt and wait for a response.
;If the user pressed enter (to select the default) sd will be null,
;so set sd to use the default value from $sd.
;If the user entered a new value instead of accepting the default,
;then set that to be the new default for the next time.
 And for future knowledge, if you can provide a brief description of your issue in the subject (as opposed to Help Please), you will likely get better responses.  I know that if I've got a couple min to spare (such as I'm waiting at my desk for someone so I can't really start a new task), I'll visit the forums and skim through the message list looking for something that I think I can answer relatively quickly.  In such a case, I typically wouldn't click on the "Help Please" subject as I have NO IDEA what it's about -- I leave those for when I have more time to "just browse".  Instead, I'll click on the message with a subject that does look like something I can help with.
If I were a betting man, I'd bet that there are others out there who do the same thing.  I think you just got lucky here in that Henrique had more time to spare.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
agent47x
in reply to: doni49
thanks for the solution and time for both of you guys..learning lisp its not easy without your help i hope someday i can help other people about lisp..
doni49
If you're trying to learn autodesk, there are three tutorial sites that I'll point you to:
www.jefferypsanders.com
www.afraliplsp.net
www.lee-mac.com (provided by our very own @lee-mac)
Don Ireland
doni49
Autocorrect got me that should have said "learning autolisp".
Don Ireland
Kent1Cooper
Here's another [and shorter, omitting the comments] way that I usually do that default thing for numerical values, which requires neither pre-(setq)ing a default value if it's not already there nor using a temporary-value [sd above] variable:
(setq $sd
  (cond
    ((getreal (strcat "\nSpecify Radius <" (if $sd (rtos $sd 2 1) "2.0") ">: ")))
      ; User-types-value condition [nil on Enter]; offer prior value as default if present, 2.0 on first use
    ($sd); User hit Enter with prior value [subsequent use]
    (2.0); User hit Enter without prior value [first use]
  ); end cond
); end setq
Kent Cooper, AIA
”Boost
