Visual LISP, AutoLISP and General Customization
*Engenharia, Projetar
Message 1 of 12 (147 Views)
Help me, Please!
147 Views, 11 Replies
02-02-2000 10:10 AM
How can use the Osnap "APParent Intersect" into a Lisp.
Others osnap options use only one point as CENter option below:
(setq pt2 (osnap pt1 "cen"))
But to use APParent Intersect ou Perpendicular is necessary two points.
I've tried use:
(setq pt2 (osnap pt1 "app"))
(setq pt2 (osnap pt1 pt2 "app"))
(setq pt2 (osnap pt1 "app" pt2))
(setq pt2 (osnap "app" pt1 pt2))
But none of them works.
Can Someone help me??
*Oquendo, Frank
Message 2 of 12 (147 Views)
Re: Help me, Please!
02-02-2000 10:13 AM in reply to: *Engenharia, Projetar
That has been the topic of more than one post in recent weeks. It seems
there is no way to do it short of using the INTERS function.
"Projetar Engenharia" wrote in message
news:879ru8$2q811@adesknews2.autodesk.com...
> I've tried use:
> Thanks
*Nehls, Kevin
Message 3 of 12 (147 Views)
Re:
02-02-2000 10:34 AM in reply to: *Engenharia, Projetar
That's the way that my "apparent intersection" routine works in R12 (no
apparent intersection osnap).
Kevin Nehls
for reply remove -ns-
Frank Oquendo wrote in article
<879s43$2qa10@adesknews2.autodesk.com>...
*Tanzillo, Tony
Message 4 of 12 (147 Views)
02-02-2000 11:48 AM in reply to: *Engenharia, Projetar
If you're using AutoCAD 2000, you can use (vla-intersect-with)
to do the equilvalent of APPINT (including curves, which the
(inters) function can't be used for).
> I've tried use:
> Thanks
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
*Nehls, Kevin
Message 5 of 12 (147 Views)
Re:
02-02-2000 11:55 AM in reply to: *Engenharia, Projetar
AWESOME, thank you Tony. Now I can easily upgrade my routines (as we are
in the process of upgrade to A2K)
Thanks.
Kevin Nehls
Tony Tanzillo wrote in article
<389889F7.C0B6555A@worldnet.att.net>...
*Ingram, Mark
Message 6 of 12 (147 Views)
Re:
02-02-2000 12:03 PM in reply to: *Engenharia, Projetar
I get ""no function definition (vla-intersect-with)"" in Acad2000.
Mark
Tony Tanzillo wrote in message <389889F7.C0B6555A@worldnet.att.net>...
>> I've tried use:
>> Thanks
*Bell, R. Robert
Message 7 of 12 (147 Views)
Re:
02-02-2000 12:13 PM in reply to: *Engenharia, Projetar
Did you (vl-load-com)?
R. Robert Bell, MCSE
Network Administrator (or, Modern-day Wizard)
(remove the "not." in my address for direct e-mail)
Mark Ingram wrote in message
news:87a2tq$2qe22@adesknews2.autodesk.com...
> Mark
> >> I've tried use:
> >> Thanks
*Tanzillo, Tony
Message 8 of 12 (147 Views)
Re:
02-02-2000 12:40 PM in reply to: *Engenharia, Projetar
Sorry - the method name is (vla-intersectWith).
> Mark
> >> I've tried use:
> >> Thanks
*Ingram, Mark
Message 9 of 12 (147 Views)
Re:
02-02-2000 12:50 PM in reply to: *Engenharia, Projetar
Thanks. Also, why does this not appear in help?
Mark
*Oquendo, Frank
Message 10 of 12 (147 Views)
Re:
02-02-2000 12:59 PM in reply to: *Engenharia, Projetar
It does but it does so in the wrong language. If you highlight
vla-intersectwith and press the help button, you get help on the VBA
version. This is because vla functions are actually LISP wrappers for
ActiveX methods.
"Mark Ingram" wrote in message
news:87a5lv$2q832@adesknews2.autodesk.com...
> Mark
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
