Here you go.
The following group codes apply to leader entities. In addition to the group
codes described here, see Common Group Codes for Entities . For information
about abbreviations and formatting used in this table, see Formatting
Conventions in This Reference . Leader group codes
Group codes Description
100 Subclass marker (AcDbLeader)
3 Dimension style name
71 Arrowhead flag: 0 = Disabled; 1 = Enabled
72 Leader path type: 0 = Straight line segments; 1 = Spline
73 Leader creation flag (default = 3):
0 = Leader created with text annotation
1 = Created with tolerance annotation
2 = Created with block reference annotation
3 = Created without any annotation
74 Hook line direction flag:
0 = Hook line (or end of tangent for a splined leader) is the opposite
direction from the horizontal vector
1 = Hook line (or end of tangent for a splined leader) is the same direction
as horizontal vector (see code 75)
75 Hook line flag: 0 = No hookline; 1 = Has a hookline
40 Text annotation height
41 Text annotation width
76 Number of vertices in leader (ignored for OPEN)
10 Vertex coordinates (one entry for each vertex)
DXF: X value; APP: 3D point
20, 30 DXF: Y and Z values of vertex coordinates
77 Color to use if leader's DIMCLRD = BYBLOCK
340 Hard reference to associated annotation (mtext, tolerance, or insert
entity)
210 Normal vector
DXF: X value; APP: 3D vector
220, 230 DXF: Y and Z values of normal vector
211 "Horizontal" direction for leader
221, 231 DXF: Y and Z values of "horizontal" direction for leader
212 Offset of last leader vertex from block reference insertion point
222, 232 DXF: Y and Z values of offset
213 Offset of last leader vertex from annotation placement point
223, 233 DXF: Y and Z values of offset
Xdata belonging to the application ID "ACAD" follows a leader entity if any
dimension overrides have been applied to this entity. See Dimension Style
Overrides .
-Jason
matthew wrote in message
news:38D5641BB40B6589634D1A29DBA8E538@in.WebX.maYIadrTaRb...
> would soomeone be kind enough to cut and paste the dxf codes for leader
> entities, i currently have no help files . .. thanks
