Help for selecting multiple objects to export their coordinates and ID
7 REPLIES 7
Message 1 of 8
koukouyuqi
2092 Views, 7 Replies
Hi Sirs
I am just starting learning lisp, And I am looking for a fast way to select multiple objects (usually circle) and export their coordinates and ID into a excel sheet through lisp programming.
As you might see in the attached drawing, the red circles are objects wanted. I have been trying to export their coordinates as well as their IDs in grids, e.g D28, Easting:  Northing:  . I still haven't found a good way to export ID for each circle.
As my code doesn't work, I wonder what's the most effective way to detect errors in lisp
Thx
Ji
Tags (2)
7 REPLIES 7
Message 2 of 8
hgasty1001
in reply to: koukouyuqi
What do you mean by ID? circles have no ID as a property, may be you need the text inside, are they circles or blocks with attributes?.
The "attached drawing" it's not a drawing, just a pdf of no use for test.
Any way, if you are looking for the text inside circle here are some ideas and some code:
1.-Get a selection set with the circles (setq ss (ssget  '((0 . "CIRCLE")))
2.-Get the radious and center of each circle in the selection set
3.-Create a list of points for use in window polygon selection and filter for text for each circle:
 This will create the list of points to pass as a window polygon ("WP") option to ssget
(defun DiscretizeCircle(center radius n / ii delta px pxlist oldosmode)
  (setq ii 0)
  (setq delta (/ (* 2 pi) n))
  (while (< ii n)
    (setq px  (polar center (* delta ii) radius))
    (setq pxlist (cons px pxlist))
    (setq ii (+ ii 1))
pxlist
 This will return the first text entity found, ignoring others inside the same circle (aprox)
(defun GetTxtInsideCircle(center radius / pxlist ss txt ret)
  (setq pxlist (DiscretizeCircle center radius 8))
  (setq pplist pxlist)
  (setq ss (ssget "wp" pxlist '((0 . "TEXT"))))
  (if ss
    (progn
      (setq txt (ssname ss 0))
      (setq ret (cdr (assoc 1 (entget txt))))
ret
 4.- Now you have the text, the radious and the center of each circle
 5.-Write this info to CSV file
Gaston Nunez
Message 3 of 8
dgorsman
in reply to: hgasty1001
Kelowna - beautiful small city.
To expand a bit more, use the Visual LISP editor to check for matching parenthesis, contextual hightlighting, and to step through the code one statement at a time.  All are useful for finding problems.
For the grid references of the circles, if they are not blocks with attributes you could generate a list of coordinates for each x- and y-series of defined grid values.  By checking the x/y coordinates against the two lists, you can reverse engineer the appropriate grid identifier.  If all the circles are supposed to be on-grid, you could also use this to filter out most other circles (provided everything is drawn accurately).
Message 4 of 8
koukouyuqi
in reply to: dgorsman
thx a lot, it's really helpful
Message 5 of 8
koukouyuqi
Thx a lot
Message 6 of 8
Hallex
Try this code, pay attention to change circle layer name
and circle radius, I've marked those lines within the code
Say me how it will works for you
Cheers 🙂
Message 7 of 8
macm.flais
in reply to: Hallex
Hi: Can i use this code to get the x, y and z coordinates of some circles in metric units? Thanks
Message 8 of 8
hmsilva
in reply to: macm.flais
Hi macm.flais,
change
 (setq tmp (list (rtos (* rad 2) 3 3) (rtos (car cp) 3 3) (rtos (cadr cp) 3 3)))
 to
 (setq tmp (list (rtos (* rad 2) 2 3) (rtos (car cp) 2 3) (rtos (cadr cp) 2 3)))
Henrique
”Boost
