Before, you must create TextStyle.
You can use this for it.
(if (not (tblsearch "STYLE" "TRANSPORT")) (entmake '( (0 . "STYLE") (5 . "40") (100 . "AcDbSymbolTableRecord") (100 . "AcDbTextStyleTableRecord") (2 . "TRANSPORT") (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 1.0) (3 . "ARIAL.TTF") (4 . "") ) ) )
After this, save your line type in TRANSPORT.LIN with définition:
*transport,altern A,0,["\U+25A0",transport,S=1,R=0,X=-0.595,Y=-0.3215],-0.6435,["\U+25A1",transport,S=1,R=0,X=-0.595,Y=-0.3215],-0.6435
Then load the file with "_LINETYPE"
Cadastroumph,
I tried the information that you provided and when I try to load the linetype it says there is a bad definition of transport at line 7 of the file.
What needs to be done to fix that so it will work?
splautz44 a écrit :Cadastroumph,
Badly copied? I attach the file
For the code lisp, copy and paste directly in command line before load LIN file
I got it to work. I would like to make the line thinner. What diminsions do I have to change in the .lin file to make it thinner?
splautz44 a écrit :I got it to work. I would like to make the line thinner. What diminsions do I have to change in the .lin file to make it thinner?
Isn't possible, try to find another character in table, here is a white & black square
splautz44 a écrit :Also, the endpoint of the line is not correct. The line stops short of the endpoint.
It is typically with all linetypes customised
If you mean the overall width of the resulting linetype, apply a Linetype Scale to vary the size. If you mean the thickness of the side-edge parts where it's not filled in solid, relative to the overall width, that's what you can't vary if you're using a character in a TrueType font. But you could if you make it by Shapes embedded in the linetype, in which case you would adjust the thickness of the side line elements with pen width, e.g. by the color of the resulting objects if you use color-based lineweights in plotting/printing.
Also, do you ever need to use this on curves? If so, a Shape-based linetype definition, using a few insertions in series of a Shape consisting of only top and bottom edges, followed by a few insertions of a solid-filled Shape, would get closer to following curvature, though it would still be in segmented short straight pieces, which would be more or less obvious depending on how tight the curvature is.
To elaborate on CADaStroumph's reply: It is part of the nature of all non-continuous linetypes that they can only put in the non-continuous elements in complete cycles of the linetype definition. Any length of drawn elements beyond whole multiples of the linetype definition cycle will always be filled in with continuous end segments. If whatever you're drawing allows, you can minimize that by changing the lengths of things [whether by dragging grips or via commands such as Lengthen/Trim/Extend/Break] to "tighten them down" relative to the linetype definition cycle, but obviously that's not always an option. If you can't do that, and can't live with the continuous end parts, you might need to do something like use Mline for the sides, and something else for the dashed middle parts, which you could presumably adjust the length of for the appearance you want. But of course that would then involve two separate entities overall, and they could behave in ways you won't like if [for instance] you Stretch them in a direction not parallel to their end direction.
@Kent1Cooper wrote:
.....Also, do you ever need to use this on curves? If so, a Shape-based linetype definition, using a few insertions in series of a Shape consisting of only top and bottom edges, followed by a few insertions of a solid-filled Shape, would get closer to following curvature, though it would still be in segmented short straight pieces, which would be more or less obvious depending on how tight the curvature is.
Such as the attached. I made the Shapes overlap a little, to accommodate a certain degree of curvature without gaps -- you can adjust the spacing if you like, or the number of OPEN and CLOSED Shapes in series. I also set it up to be closed at the ends, but if that doesn't matter, you could start with the OPEN ones or the CLOSED ones, or however you prefer it to come out. In a drawing with a LTSCALE System Variable setting of 1, entities with a Linetype Scale of 1 will be 1 drawing unit wide. Use a plotting lineweight sufficient to make the CLOSED ones fill in solidly. Fix the Shape-file name in the Linetype definition to whatever you put it in, and adjust the Shape number if necessary, etc.
