Guys can you figure this out?
1 REPLY 1
olbapxpablo
263 Views, 1 Reply
Sorry for being Noob here.
im learning basic LISP and it works well on me 🙂
But while im working on adding tag/label on trench OSP Routing drawing the "quick propeties" sudenlly pop up with exact qty of the polyline i selected and idea comes up on my mind, if i can make lisp the same with "quick properties" with output of text/mtext or leader .
is that posible?
i start making on idea of "tlen.lisp" it also generate result with qty of polyline selected with total measurement  but i can't make it on txt/mtxt or leader  😞
guys help me.
1 REPLY 1
hmsilva
in reply to: olbapxpablo
For the next time, post the code you have started to write...
As a demo:
(vl-load-com)
(defun c:demo (/ ent i lst n osm pt pt1 ss str)
  (setq osm (getvar 'OSMODE))
  (if (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
           (setvar 'osmode 512)
           (setq pt (getpoint "\nSpecify leader insertion point: "))
           (setvar 'osmode 0)
           (setq pt1 (getpoint pt "\nSpecify text insertion point: "))
    (progn
      (repeat (setq i (sslength ss))
        (setq ent (entget (ssname ss (setq i (1- i)))))
        (if (not (setq lt (cdr (assoc 6 ent))))
          (setq lt (cdr (assoc 6 (tblsearch "LAYER" (cdr (assoc 8 ent))))))
        (if (and lst
                 (setq n (cadr (assoc lt lst)))
          (setq lst (subst (list lt (1+ n)) (assoc lt lst) lst))
          (setq lst (cons (list lt 1) lst))
        (setq str "")
        (foreach x lst
          (setq str (strcat str (car x) " - " (itoa (cadr x)) "\\P"))
      (command "_.leader" pt pt1 "" (vl-string-right-trim "\\P" str) "")
  (setvar 'osmode osm)
  (princ)
Hope that helps
Henrique
”Boost
