Visual LISP, AutoLISP and General Customization
grouping numbers
8 REPLIES 8
Message 1 of 9
markruys2
719 Views, 8 Replies
grouping numbers
i am trying to group nubers together whichever consecutive
for example : original list '(1 2 3 6 9 10 11 44 55 56 77) in a list
outpot list  '((1 2 3)(6)(9 10 11)(44)(55 56)(77))
seems to be simple, but have been strugglig for a day or so...
any help will be gratly appreciated
TIA
8 REPLIES 8
Message 2 of 9
Kent1Cooper
in reply to: markruys2
This seems to do that:
(defun CGI (numlist / sublist lastint cumlist); = Consecutively-Grouped Integers
  (setq sublist (list (setq lastint (car numlist)))); start first sublist with first integer
  (foreach int (cdr numlist)
    (if (= int (1+ lastint)); consecutive from previous?
      (setq sublist (append sublist (list int))); then -- add it to consecutive group
      (setq ; else
        cumlist (append cumlist (list sublist)); add so-far group to cumulative list
        sublist (list int); start new sublist
      ); setq
    ); if
    (setq lastint int)
  ); foreach
  (setq cumlist (append cumlist (list sublist))); add last group
); defun
Usage:
Command: (cgi '(1 2 3 6 9 10 11 44 55 56 77))
returns
((1 2 3) (6) (9 10 11) (44) (55 56) (77))
Kent Cooper, AIA
Message 3 of 9
markruys2
in reply to: Kent1Cooper
kent,
thanks for the code, compact and simple
have a nice thankgiving
m
Message 4 of 9
Kent1Cooper
@markruys2 wrote:
kent,
m
My pleasure.  It also occurs to me that it would be easy to have the routine sort the initial list into order, if it may not always be already, just in case.
Kent Cooper, AIA
Message 5 of 9
Dang! I was too slow.
The following will sort *and* not drop duplicate numbers (like vl-sort does).
(defun gl (lst / sl li ml)
;;; quick number grouping
;;; by me
;;; requires (std-%insertion-sort)
;;; by Serge Pashkov
;;; usage example: (gl '(1 3 4 6 7 8 9 1 4 67)) => ((1 1) (3 4 4) (6 7 8 9) (67))
	(setq sl (list (nth 0 (std-%insertion-sort lst '<))) ml ())
	(foreach li (cdr (std-%insertion-sort lst '<))
		(if (or (member li sl) (= li (1- (last (std-%insertion-sort sl '<)))) (= li (1+ (last (std-%insertion-sort sl '<)))))
			(setq sl (std-%insertion-sort (cons li sl) '<))
			(setq	ml (cons sl ml)
					sl (list li)
	(setq ml (reverse (cons sl ml)))
(defun std-%insertion-sort (lst cmp / M N O cO)
;;; --Part of STDLSP.LSP By: Reini Urban
;;; stable insertion sort, fast for already ordered and short lists
;;; very slow for reversed or random lists O(n^2)
  (setq O (reverse lst) M nil N (list (car O)))
  (while (setq O (cdr O))
    (setq cO (car O))
    (while (and N (apply cmp (list (car N) cO)))
      (setq M (cons (car N) M)
            N (cdr N)))
    (setq N (cons cO N))
    (while M
      (setq N (cons (car M) N) M (cdr M))))
  N)
Message 6 of 9
Kent1Cooper
Interesting idea, if duplicates are a possibility.  A more concise way than std-%insertion-sort to sort a list of numerical values and not drop duplicate numbers:
;; SKD = Sort, Keep Duplicates [unlike vl-sort, which eliminates them]
;; for a list of numerical values
(defun SKD (numlist oper / sortlist)
  (foreach x (vl-sort numlist oper)
    (setq sortlist (append sortlist (vl-remove-if-not '(lambda (y) (= y x)) numlist)))
  ); foreach
); defun
Usage:
Command: (skd '(1 3 4 6 7 8 9 1 4 67) '<)
returns
(1 1 3 4 4 6 7 8 9 67)
Incorporating that approach into my earlier CGI function:
(defun CGI (numlist / sortlist sublist lastint cumlist); = Consecutively-Grouped Integers
  (vl-load-com); [if needed]
  (foreach x (vl-sort numlist '<)
  ); foreach
  (setq sublist (list (setq lastint (car sortlist)))); start first sublist with first integer
  (foreach int (cdr sortlist)
    (if (or (= int lastint) (= int (1+ lastint))); equal to or consecutive from previous?
      (setq ; else
      ); setq
    ); if
    (setq lastint int)
  ); foreach
); defun
Usage:
Command: (cgi '(1 3 4 6 7 8 9 1 4 67))
returns
Kent Cooper, AIA
Message 7 of 9
pbejse
TIA
Recursion
(Defun groupbycon (n ls ls_)
  (setq s (apply 'min ls)
        ls_ (cons s ls_)
	ls  (vl-remove s ls)
  (While (member (Setq s (1+ s)) ls)
    (setq ls_ (cons s ls_)
	  ls  (vl-remove s ls)
  (if ls
    (groupbycon (setq n (cons (reverse ls_) n)) ls nil)
    (reverse (cons ls_ n))
(groupbycon nil '(1 2 3 6 9 10 11 44 55 56 77) nil)
(groupbycon nil '(56 1 2 10 11 3 55 6 9 44 77) nil)
HTH
Message 8 of 9
phanaem
in reply to: pbejse
Nice one pBe
Here is mine, for non-duplicates list
(defun group_consecutive (l / r)
  (setq r (list (list (apply 'max l))))
  (foreach x (cdr (vl-sort l '>))
    (if
      (= x (1- (caar r)))
      (setq r (cons (cons x (car r)) (cdr r)))
      (setq r (cons (list x) r))
Message 9 of 9
pbejse
in reply to: phanaem
@phanaem wrote:
Nice one pBe
Clever using MAX and sort phanaem , i like your code
Iteration version of the code  using max
(Defun groupbycon (ls / n)
  (setq s (apply 'max ls))
  (While ls
    (while (member s ls)
	    ls	(vl-remove s ls)
	    s	(1- s)
    (setq n   (cons ls_ n)
	  ls_ nil s (apply 'max ls)
  n
”Boost
