Group Code 330
4 REPLIES 4
571 Views, 4 Replies
Group Code 330
Below are the group codes for a hatch object. The first code 330, I'm not
sure what this represents. However, the second code 330... (330 .
name: 40032130>) ...Is the associated region object, which I am trying to
access.
I use... (setq getx (cdr (assoc 330 (entget (ssname vergetdxf 0))))) ... to
access the entity name but it always returns the first 330 entity and not
the second. How do I access the second?
((-1 . ) (0 . "HATCH") (330 .
4008ecf8>)(5 . "9F") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0")
(100 .
"AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 . "ANSI31") (70 . 0) (71
. 1) (91 . 1) (92 . 1) (93 . 4) (72 . 1) (10 23.3562 3.37284 0.0) (11
25.0247
3.37284 0.0) (72 . 1) (10 25.0247 3.37284 0.0) (11 25.0247 4.90168 0.0) (72
. 1) (10 25.0247 4.90168 0.0) (11 23.3562 4.90168 0.0) (72 . 1) (10 23.3562
4.90168 0.0) (11 23.3562 3.37284 0.0) (97 . 1) (330 .
40032130>)(75 . 0) (76 . 1) (52 . 0.0) (41 . 1.0) (77 . 0) (78 . 1) (53 .
0.785398)(43 .
0.0) (44 . 0.0) (45 . -0.0883883) (46 . 0.0883883) (79 . 0) (98 . 1) (10 0.0
0.0 0.0))
Thank you,
Edward
4 REPLIES 4
BillZ
This is the way I did it to find all the groups in a dictionary:
(while (member (assoc 330 grp) grp)
(setq glt (append glt (list (cdr (assoc 330 grp))))
grp (cdr (member (assoc 330 grp) grp)) ;list of associated groups.
) ;end while
BillZ
I'm a little lost with this one...
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
This
              (setq
                    grp
          ) ;end while
BillZ
BillZ
GRP is the association list of the hatch object you described. this loop will return a list of all assoc 330s' in the association list. you can then select the one you want from the list to get the information you want with the entget function.
BillZ
Got it!
Thanks for your help.
I wound up using this:
(setq glt (list (cdr (assoc 330 grp)))
  ) ;end while
GRP
function.
BillZ
”Boost
