On Mon, 15 Oct 2007 09:25:06 +0000, Fatty <> wrote:
>Hi Ian
>Here is one from my oldies that written for A2000
>Hope it will works in your version too
>Create layer on each type of a material with different colors
>Auxiliary function reads a layer and chooses density
>You need to put the values in function testofdens
>instead of dummy values I have put
>(I.e. instead of 7.8, 5.6, 2.4 8.61, 6.8)
>Certainly you will have other names of layers
>Replace in those seats where I have put a sign; | ***** |;
>How many types of a material are so much layers.
>Convert mass properties accordingly your current units
Thanks for that.
For me, it is generally just one material - steel (structures) or
aluminium (windows and curtain walling) so I don't have them on
separate layers. I also have to provide full cutting lists with each
individual element listed and an estimated mass for it.
What prompted this was a rather messy job where I was fed incorrect
information on the total job mass. I quoted a $/tonne figure, but it
turns out that the fabricator is claiming that the actual tonneage is
around 30% less than the figure I have worked out. Of course their
transport and galvanising records clearly show this 30% discrepancy.
With some 400 assemblies and each assembly comprising something like 6
or more individual items, I almost wore the spots off my calculator.
I will have a look through things and see what I can use. It is a pity
that AutoCAD does not let you simply nominate what the default
material bulk density is - at least I have not been able to find it.
Thanks again.
Ian A. White, CPEng.
| /| / WAI Engineering
| /_| / Sydney 2000
|/ |/ Australia
www.wai.com.au
mailto:ianwhite@wai.com.au
callto://waiwhite on Skype
