getting an insertion point of a block
11 REPLIES 11
Message 1 of 12
402 Views, 11 Replies
If I have a specific block that is present in a drawing, is there anyway of getting the insertion point data of that block via lisp to use as an insertion point for a different block insertion?
11 REPLIES 11
Message 2 of 12
To select the block and return the insertion point
use this
(cdr (assoc 10 (entget (car (entsel "\nSelect
insert: ")))))
-Jason
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
If
Message 3 of 12
Lets say the block is called XXX and I know that and I want to limit the amount of user interaction. I want them to be able to select block XXX or YYY from a list and then let lisp do the rest based on their selection. Is there a way to specify that block name rather than picking it?
Message 4 of 12
How about this...
(defun InsertInsPt ( BlockName )
  (cdr
(assoc 10 (entget (tblobjname "block" BlockName))))
;Example:
(InsertInsPt "YourBlockNameHere")
-Jason
it?
Message 5 of 12
That will return (0.0 0.0 0.0)
(defun InsertInsPt (BlockName)
 (setq
ss (ssget "x" (list (cons 2 BlockName))))
 (if ss
  (cdr (assoc
10 (entget (ssname ss 0))))
  (alert (strcat "No " BlockName  " block
found: "))
This assumes only one block named BlockName in the
drawing.
How about this...
  (cdr
;Example:
-Jason
it?
Message 6 of 12
oops.  I tested it with a block that the
Insertion point happened to be 0,0.
(defun InsertInsPt (BlockName /
ss)
-Jason
 (setq
 (if ss
  (cdr (assoc
block found: "))
the drawing.
How about this...
  (cdr
;Example:
-Jason
it?
Message 7 of 12
This is why I mention including your ACAD release
in my latest post. Hopefull you are running R2000 or above.
Try this..
Rotate the current UCS by 90d in Z
axis
Insert a block.
Switch back to the previous UCS.
(defun c:prac ()
(alert "This will not return a
point in the WCS")
Insert: ")))))
(defun c:prac2 ()
(alert "This will return a point in the
WCS")
 (vl-load-com)
 (setq obj (vlax-ename->vla-object (car
(entsel "\nSelect Insert: "))))
 (vlax-safearray->list
(vlax-variant-value (vla-get-insertionPoint Obj)))
Don
If
Message 8 of 12
After reading your message again, I'm not sure this
is the answer you were looking for. The other guys probably answered
correctly.
Don
Try this..
axis
Insert a block.
(defun c:prac ()
a point in the WCS")
Insert: ")))))
(defun c:prac2 ()
WCS")
 (vl-load-com)
(car (entsel "\nSelect Insert: "))))
Don
If
insertion?
Message 9 of 12
Thanks Jim,
Is the 'x' supposed to be a certain value .... I get a too few arguments error when I try to run it
here's the code I used:
(defun c:InsertInsPt (phil)
(setq ss (ssget "x" (list (cons 2 phil))))
(if ss
(cdr (assoc 10 (entget (ssname ss 0))))
(alert (strcat "No " phil " block found: "))
'phil' is the name of the block that is defined.
Message 10 of 12
Change the (defun c:InsertInsPt (phil) to (defun
InsertInsPt (phil / ss)
The to use the command to find the insert point of
a block named widget
    (insertinspt
"widget")
Jim,
phil))))
 (if ss
0))))
defined.
Message 11 of 12
(defun InsertInsPt (phil / ss)
(if ss
I thought this might be a little easier way of corresponding ... I hope you don't mind.
I'm a little rusty on the lisp end of things but I basically understand what is going on here.
The block name is 'phil' and the insertion point is 2,2,0.
ssget "x" will return all the objects in the drawing.
I'm not real clear on what cons does.
when I attempt to run this, I get a bad SSGET list value.
any help that you might be able to provide would be greatly appreciated
Message 12 of 12
If you see my post, the point returned by DXF 10
may have to be translated to the current UCS to be accurate.
Don
(defun
 (if ss
don't mind.
drawing.
appreciated
”Boost
