Visual LISP, AutoLISP and General Customization
Getting a Selection Set after Paste
8 REPLIES 8
Message 1 of 9
1228 Views, 8 Replies
Hey Gang
Tried a search found nothing.  Is it possible to get a selection set of what was just pasted into drawing?  Thanks
Southie
8 REPLIES 8
Message 2 of 9
devitg
select
p
Message 3 of 9
3wood
Instead of Ctrl+V, use Ctrl+Shift+V to paste as a block. Then explode it with "L" selection. Now you have pasted objects in "P" selection.
Message 4 of 9
Dev
Tried (ssget "P"))  I think i see what you mean even though the sel set is not the entities after paste but what was origanaly selected.  In my case this will work but if i wanted to get the new handles after pasting not sure on that.
Southie
Message 5 of 9
in reply to: 3wood
3wood
Can what you recomended be done thru code?  Would like user to just use pasteclip and just drag to where the want it?
Southie
Message 6 of 9
3wood
Got your idea.  User can choose paset as block instead of just paste.  Thanks again.
Message 7 of 9
3wood
If using lisp code, you can record the last entity handle before pasting. Then after pasting, go through entire entity database from the latest entity, comparing with previous record, if is newer, add it to a selection.
Message 8 of 9
Kent1Cooper
in reply to: 3wood
I think the same can be accomplished without making any comparisons of one thing with another to figure out which is newer -- you should be able to just go to the next until there aren't any more.  I'm not in a place where I can test it, but try something like this:
(defun C:PandSS (/ entl ent); = Paste and turn into Selection Set
  (setq
    entl (entlast); last object in drawing prior to Paste
    pss (ssadd); = Pasted-objects Selection Set [initially empty]
  ); setq
  (command "_.pasteclip")
  (while (> (getvar 'cmdactive) 0)
    (command pause); allows possible scale/rotation options as well as insertion point
  ); while
  (while (setq ent (entnext entl)); as long as there's still another object
    (ssadd ent pss); put it in the selection
    (setq entl ent); make object just added the base to look for the next after [if any]
  ); while
); defun
That should leave the pasted objects all saved into the 'pss' selection-set variable, to do with whatever you want.
Kent Cooper, AIA
Message 9 of 9
in reply to: Kent1Cooper
All thanks for the help.  Learning all the time.
Southie
”Boost
