GetAttributes via lisp
15 REPLIES 15
Message 1 of 16
XIJIANGWOO
2064 Views, 15 Replies
Hello guys,
         I am trying to find a lisp that would get an attribute value (tag name = NBR_5) . I'm trying to run a simple routine that would let the user place the value from the titleblock attribute as text on a drawing. I see a ton of articles regarding getting attributes but I am not well versed in programming.
Any help is greatly appreciated.
Thanks in advance.
15 REPLIES 15
Message 2 of 16
alanjt_
in reply to: XIJIANGWOO
(defun _findMatchingAttributeValue (block tagstring)
  (vl-some (function (lambda (att)
                       (if (eq (vla-get-tagstring att) (strcase tagstring))
                         (vla-get-textstring att)
           (vlax-invoke block 'GetAttributes)
(_findMatchingAttributeValue <vla-object> <tagstring>)
Message 3 of 16
XIJIANGWOO
in reply to: alanjt_
Thanks Alan,
I am not familiar with Vlisp. I received this error "; error: bad argument type: VLA-OBJECT nil". What am I doing wrong? I know your answer is going to be obvious, isn't it?
thanks again.
Message 4 of 16
BlackBox_
The last line of Alan's code is an example, where you would replace <vla-object>, and <tagstring> with actual values.
Consider this pseduo-code:
(vl-load-com)
(defun c:FOO (/ _findMatchingAttributeValue ss value)
    (vl-some (function
               (lambda (att)
  (if (and (setq ss (ssget ":S:E" '((0 . "INSERT") (66 . 1))))
           (setq value (_findMatchingAttributeValue
                         (vlax-ename->vla-object (ssname ss 0))         ;<-- <vla-object>
                         "NBR_5"                                        ;<-- <tagstring>
    (prompt (strcat "\n[Attribute Value] : " value))
    (prompt "\n** Invalid selection ** ")
  (princ)
"How we think determines what we do, and what we do determines what we get."
Message 5 of 16
dbroad
It hardly worth a program.  Use ddatte. Pick the titleblock. Highlight the text. CTRL+C.  Then, CTRL+V into the drawing.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 16
alanjt_
in reply to: BlackBox_
BlackBox answered your question about converting to a vla-object. However, just for completeness, here's a non VLISP version:
(defun _findMatchingAttributeValue (block tagstring / data string)
  (while (and (not (eq (cdr (assoc 0 (setq data (entget (setq block (entnext block)))))) "SEQEND"))
              (not string)
    (if (and (eq (cdr (assoc 0 data)) "ATTRIB") (eq (cdr (assoc 2 data)) (strcase tagstring)))
      (setq string (cdr (assoc 1 data)))
  string
Message 7 of 16
BlackBox_
FWIW -
I think you'll find both of these adaptations to be *slightly* faster:
(defun _setq (block tagstring)
  (setq tagstring (strcase tagstring))
  (vl-some (function
             (lambda (att)
               (if (eq (vla-get-tagstring att) tagstring)
(defun _cond (block tagstring)
  (vl-some (function
             (lambda (att)
                       (cond (tagstring)
                             ((setq tagstring (strcase tagstring)))
... Speed test of 1000 iterations (same block, same tag😞
_FINDMATCHINGATTRIBUTEVALUE
Elapsed: 312
Average: 0.3120
_SETQ
Elapsed: 281
Average: 0.2810
_COND
Elapsed: 280
Average: 0.2800
Minor advantage; not worth recoding multiple functions, etc., IMO. Just thought I'd mention it... Again, only FWIW.
Cheers
Message 8 of 16
XIJIANGWOO
Thanks BlackBox,
   How would I revise the code to skip the block selection as it is always the same block "TitleBlockMfg" and have that attribute value placed as text ?
This is actually part of a macro that I use when I cycle through many drawings tagging specific objects with the "NBR" tag value loacate in the titleblock.
It would make life so much easier here.
Thanks for all of the help everyone !
Message 9 of 16
alanjt_
(ssget "_X" '( (0 . "INSERT") (2 . "TitleBlockMfg")))
Message 10 of 16
alanjt_
Good catch, BBox. I should have change the case of the string before hand.
Message 11 of 16
alanjt_
BTW, your _cond won't work, since it only checks if 'tagstring is an assigned variable, which it is. You need to setq a different variable for _cond.
eg.
(defun _cond (block tagstring / upcase)
  (vl-some (function
             (lambda (att)
                       (cond (upcase)
                             ((setq upcase (strcase tagstring)))
 However, I'd just stick with upcasing the string before running anything, IMO.
Message 12 of 16
BlackBox_
Yes, of course... What a silly mistake (not changing the name)... Keen eye, as always.
Cheers
Message 13 of 16
BlackBox_
@XIJIANGWOO wrote:
Thanks BlackBox,
Alan's answered your question already, about how to revise the SSGET call... Did you get your macro working they way you wanted?
Cheers
Message 14 of 16
alanjt_
Cheers
You caught my coding boo boo first. 🙂
Message 15 of 16
XIJIANGWOO
Thank Everyone. After playing with the code supplied by Blackbox, I was able to get my macro running.
I still have a lot to learn. I'm not in full time CAD like I used to be.
Xi
Message 16 of 16
BlackBox_
That is kind of you to say; I'm happy to help. :beer:
Don't we all... And you're not alone; I was just busted down to half-time myself. *Looking*
”Boost
