> {quote:title=MatteoJames wrote:}{quote}Hi all, I'm creating a lisp in which I select a block with ssget and inserts other blocks with the same name in some certain points.
> How do I get the layer, color and line type from the original block and set it the same on all the other blocks it inserts?
> Matteo
{color:#ff6600}
{color}
{color:#ff6600}You can do with 'COPY' command in AutoCAD.
No need programming.{color}
