Visual LISP, AutoLISP and General Customization
Get blocks from other drawings?
2 REPLIES 2
tvcad
148 Views, 2 Replies
Looking for an alternative to Design Center for inserting blocks from other drawings. Running A2k, W2k. Problem is that Design Center will not offer to overwrite existing blocks. Its crazy. I ask for the block in the external drawing, and Design Center says "you have to keep what you have".
I know I can purge, then insert, but that can get tedious, especially when updating multiple inserts/references.
Any routines out there? Workarounds? Thanks
2 REPLIES 2
in reply to: tvcad
No easy solution. For "importing" blocks from external drawings do a search
on this NG for "ObjectDBX". There you will find plenty of code for opening
an external drawing and using the copyobjects method for accessing all kinds
of objects.
Now for the overwriting part: someone may have a more eloquent solution but
mine would be to rename the block you plan to overwrite BEFORE importing the
new block, like "MyBlock" --> "MyBlock-trash". Then iterate through the
mspace and pspace blocks searching for all instances of "MyBlock-trash" and
replacing it with "MyBlock". Then of course delete "MyBlock-trash" from the
blocks collection.
jb
in reply to: tvcad
To overwrite...
place a copy of the desired block in DWG form
within your search path
command: -Insert
old_block_name=new_block_name
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Looking
I know I can purge,
inserts/references.
”Boost
