When (Acad version and drawing platform) were Dynamic Blocks first introduced? I guess I'm getting old and my memory fails me it would seem 😉
I see several posts about gathering modified Dynamic blocks ("`*U*") for a given block name that use ActiveX methods, specifically using the "effectiveName" property... and often people suggest a fail-over of checking to see if the property exists prior to calling for it, and if it doesn't exist then return the "Name" property to keep the routine from failing... but it makes me curious...
Did Dynamic Blocks exist before the effectiveName property was exposed/created for ActiveX? I know that the property has existed since the 2006 release (on the 2004 drawing platform).
My question is really as to why bother with the failover as you process each block in the selectionSet? A version check prior to attempting the collection of the blocks would make much more sense as it would allow you to bail-out before stepping through the selectionset at all.
But more: if Dynamic blocks existed before the property was created/exposed in ActiveX, the currently often used failover (using the "Name" property) would only return the name that was passed to it to begin with (the "*U..." block name) wouldn't it? If so, then why bother with it, again, for the same reason, you would be wasting your time iterating over the selection set... or am I way off base... did the "Name" property prior to the introduction of the "EffectiveName" property return what is now the effectiveName (IE the name of the original block definition)?
I'm Extreeeeemly curious. I know that it is possible to get the name of the originating block definition without ActiveX properties but don't want to bother introducing a mixed bag of methods if I don't need to.
-Gary
