I am wondering if it is possible to use a lisp variable in the Angle value of a Rotation Parameter attached to an attribute in order to keep it from spinning inside a dynamic block. The reason I am seeking such a complex method is because I want to use an Alignment Parameter to place the block, and the two methods I know of to keep attributes from spinning only work when you rotate the block with a Rotation Parameter.
Since the block has a rotation value after it is aligned, and the Rotation Parameter attached to the attribute has an "Angle" value, I wonder if it is possible to stick a formula or something inside that Angle value that grabs the equation of 360 minus whatever angle the dynamic block is rotated to. That would always give it a number that would orient the Rotation Parameter (and thus the attached attribute) to always be upright.
If I could insert a field in that value box I could select a Field expression for the block and rotation value, but alas, this is not an option.
