So I have a flatten routian that works on a file in model space, but when I am in block editor, and run the app it reverts back to model space and finished the command, Is there a way to proform that same command and have it work in the block editor?
(defun zeroz (key zelist / oplist nplist) (setq oplist (assoc key zelist) nplist (reverse (append '(0.0) (cdr (reverse oplist)))) zelist (subst nplist oplist zelist) );setq (entmod zelist) );defun (prompt "\nFLATTEN v.2.1 loaded. Type FLATTEN to run it.") (princ)
The function you posted appears to have no relationship to the flatten command. The built-in flatten command seems to work in bedit although it does trigger a few error messages. How is the built in flatten command not working for you?
My company did not load the express tools so I dont have a stock flatten command. Maybe I am just stuck until I get my IT department to load the Express tools.
Sorry, I didnt go high enough to copy all the code. Here it is.
; FLATTEN.LSP version 2.1, 14 Mar 94 ; ; FLATTEN sets the Z-coordinates of LINEs, POLYLINEs, CIRCLEs, ARCs, ; TEXT, Block INSERTs, POINTs, and SOLIDs to 0. ;------------------------------------------------------------------------ ; copyright 1990, 1993, 1994 by Mark Middlebrook ; Daedalus Consulting ; 435 Clifton Street ; Oakland, CA 94618 ; CompuServe ID #73030,1604 ; ; You are free to distribute FLATTEN.LSP to others so long as you do not ; charge for it. ;------------------------------------------------------------------------ ;*Why Use FLATTEN?: ; ; FLATTENing is useful in at least two situations: ; 1) You receive a DXF file created by another CAD package and discover ; that all the Z coordinates contain small round-off errors. These ; round-off errors can prevent you from object snapping to intersections ; and make your life difficult in other ways as well. ; 2) In a supposedly 2D drawing, you accidentally create one entity with a ; Z elevation and end up with a drawing containing entities partly in and ; partly outside the Z=0 X-Y plane. As with the round-off problem, this ; situation can make object snaps and other procedures difficult. ;------------------------------------------------------------------------ ;*How to Use FLATTEN: ; ; FLATTEN v.2.1 requires AutoCAD Release 12, although you can run it with ; previous versions of AutoCAD by deleting the underscores that proceed ; command and suboption names. For example, change: ; (command "._UCS" "_Restore" ...) ; to: ; (command ".UCS" "Restore" ...) ; ; To run FLATTEN, load it using AutoCAD's APPLOAD command, or type: ; (load "FLATTEN") ; at the AutoCAD Command prompt. Once you've loaded FLATTEN.LSP, type: ; FLATTEN ; to run it. FLATTEN will tell you what it's about to do and ask you ; to confirm that you really want to flatten entities in the current ; drawing. If you choose to proceed, FLATTEN prompts you to select entities ; to be flattened (press ENTER to flatten all entities in the drawing). ; After you've selected entities and pressed ENTER, FLATTEN goes to work. ; It reports the number of entities it flattens and the number left ; unflattenened (because they were entities not recognized by FLATTEN; see ; the list of supported entities above). ; ; If you don't like the results, just type U to undo FLATTEN's work. ; ; Note that FLATTEN flattens entities onto the Z=0 X-Y plane in AutoCAD's ; world coordinate system (UCS). ;------------------------------------------------------------------------ ;(defun C:FLATTEN (/ olderr oldcmd ss1 ss1len i ; numchg numnot numno0 ssno0 ename elist ; etype yorn ; ) ; ;*error handler ; (setq olderr *error*) ; (defun *error* (msg) ; (if (= msg "quit / exit abort") ; (princ) ; (princ (strcat "error: " msg)) ; ) ; (setq *error* olderr) ; (command "._UCS" "_Restore" "$FLATTEN-TEMP$" ; "._UCS" "_Delete" "$FLATTEN-TEMP$" ; ) ; (command "._UNDO" "_End") ; (setvar "CMDECHO" oldcmd) ; (princ) ; ) ; ; ;*setup ; (setq oldcmd (getvar "CMDECHO")) ; (setvar "CMDECHO" 0) ; (command "._UNDO" "_Group") ; (command "._UCS" "_Save" "$FLATTEN-TEMP$" "._UCS" "World") ; ;set World UCS ; ; ;*get input ; (prompt ; "\nFLATTEN sets the Z coordinates of Lines, Polylines, Circles, " ; ) ; (prompt ; "\nArcs, Text, Block Inserts, Points, and Solids to zero." ; ) ; ; (initget "Yes No") ; (setq yorn (getkword "\nDo you want to continue <Y>: ")) ; (cond ((/= yorn "No") ; (graphscr) ; (prompt "\nChoose entities to FLATTEN ") ; (prompt ; "[press return to select all entities in the drawing]" ; ) ; (setq ss1 (ssget)) ; (if (null ss1) ;if enter... ; (setq ss1 (ssget "X")) ;select all entities in database ; ) ;if ; ; ; ;*initialize variables ; (setq ss1len (sslength ss1) ;length of selection set ; i 0 ;loop counter ; numchg 0 ;number changed counter ; numnot 0 ;number not changed counter ; numno0 0 ;number not changed and Z /= 0 counter ; ssno0 (ssadd) ;selection set of unchanged entities ; ) ;setq ; ; ;*do the work ; (prompt "\nWorking.") ; (while (< i ss1len) ;while more members in the SS ; (if (= 0 (rem i 10)) ; (prompt ".") ; ) ; (setq ename (ssname ss1 i) ;entity name ; elist (entget ename) ;entity data list ; etype (cdr (assoc 0 elist)) ;entity type ; ) ;setq ; ; ;*change group 10 Z coordinate to 0 for listed entity types ; (if (member etype ; '("LINE" "POLYLINE" "TEXT" ; "INSERT" "CIRCLE" "ARC" ; "POINT" "SOLID" ; ) ; ) ; (setq elist (zeroz 10 elist) ; ;change entities in list above ; numchg (1+ numchg) ; ) ;setq ; (progn ;leave others alone ; (setq numnot (1+ numnot)) ; (if (/= 0.0 (car (reverse (assoc 10 elist)))) ; (progn ;add it to special list if Z /= 0 ; (setq numno0 (1+ numno0)) ; (ssadd ename ssno0) ; ) ;progn ; ) ;if ; ) ;progn ; ) ;if ; ; ;*change group 11 Z coordinate to 0 for LINEs, TEXT, and SOLIDs ; (if (member etype '("LINE" "TEXT" "SOLID")) ; (setq elist (zeroz 11 elist)) ; ) ;if ; ; ;*change groups 12 and 13 Z coordinate to 0 for SOLIDs ; (if (member etype '("SOLID")) ; (progn ; (setq elist (zeroz 12 elist)) ; (setq elist (zeroz 13 elist)) ; ) ; ) ;if ; ; (setq i (1+ i)) ;next entity ; ) ;while ; (prompt " Done.") ; ; ;*print results ; (prompt (strcat "\n" (itoa numchg) " entity(s) flattened")) ; (prompt ; (strcat "\n" (itoa numnot) " entity(s) not flattened") ; ) ; ; (if (/= 0 numno0) ;if there any entities in ssno0, show them ; (progn ; (prompt (strcat " [" ; (itoa numno0) ; " with non-zero base points]" ; ) ; ) ; (getstring ; "\nPress enter to see non-zero unchanged entities... " ; ) ; (command "._SELECT" ssno0) ; (getstring "\nPress enter to unhighlight them... ") ; (command "") ; ) ;progn ; ) ;if ; ) ; ) ;cond ; ; (command "._UCS" "_Restore" "$FLATTEN-TEMP$" ; "._UCS" "_Delete" "$FLATTEN-TEMP$" ; ) ; (command "._UNDO" "_End") ; (setvar "CMDECHO" oldcmd) ; (setq *error* olderr) ; (princ) ;) ;defun ; ; ; ; ;*function to change Z coordinate to 0 ; ;(defun zeroz (key zelist / oplist nplist) ; (setq oplist (assoc key zelist) ; nplist (reverse (append '(0.0) (cdr (reverse oplist)))) ; zelist (subst nplist oplist zelist) ; ) ;setq ; (entmod zelist) ;) ;defun ; ;(prompt "\nFLATTEN v.2.1 loaded. Type FLATTEN to run it.") ;(princ) ;
