I was wondering how to extract the scale and angle of a picked hatch so that I can pass it to a routine that uses the same settings?
Gordon
Solved by Kent1Cooper. Go to Solution.
Check this out , it would print all dxf codes to the command line .
(entget (car (entsel "\n Select an entity :")))
Tharwat
@Gordon_S wrote:I was wondering how to extract the scale and angle of a picked hatch so that I can pass it to a routine that uses the same settings?
Here's the Hatch portion of a larger routine of mine that gets various kinds of information from various object types, and sets the appropriate system variables to match. The 'objtyp' and 'objdata' variables are extracted earlier from the selected entity.
((= objtyp "HATCH")
(setvar 'hpname (cdr (assoc 2 objdata))); hatch pattern
(if (wcmatch (getvar 'hpname) "U,_USER")
(progn
(setvar 'hpspace (cdr (assoc 41 objdata))); SPACING [= scale for User-defined pattern]
(setvar 'hpdouble (cdr (assoc 77 objdata)))
); end progn
); end if
(if (/= (getvar 'hpname) "SOLID"); patterns other than Solid
(progn
(setvar 'hpscale (cdr (assoc 41 objdata))); SCALE
(setvar 'hpang (cdr (assoc 52 objdata))); ANGLE
); end progn
); end if
(setvar 'hpassoc (cdr (assoc 97 objdata)))
); end Hatch object type
here's another one
(defun c:Hinfo (/ HatchEnt HAngle Hscale) (vl-load-com) (cond ((and (setq HatchEnt (entsel "\nSelect Hatch Pattern:")) (eq (cdr (assoc 0 (entget (setq HatchEnt (car HatchEnt))))) "HATCH") (setq HatchEnt (vlax-ename->vla-object HatchEnt)) (princ (strcat "\nAngle\t" (rtos (/ (* (setq HAngle (vlax-get-property HatchEnt "PatternAngle")) 180.0) pi) 2 2))) (princ (strcat "\nScale\t" (rtos (setq Hscale (vlax-get-property HatchEnt "PatternSpace")) 2 2))) ))) (princ) )
The values for Scale and Angle are stored on Hscale and Hangle variable...
or a shorter one, that is if you dont mind showingthe RAW value
(defun c:Hinfo (/ HatchEnt) (vl-load-com) (cond ((and (setq HatchEnt (entsel)) (eq (cdr (assoc 0 (entget (setq HatchEnt (car HatchEnt))))) "HATCH") (setq HatchEnt (vlax-ename->vla-object HatchEnt)) (foreach Info '("PatternAngle" "PatternSpace") (princ (strcat "\n" Info "\t" (rtos (set (setq n (read info)) (vlax-get-property HatchEnt Info)) 2 2))) ) )))(princ) )
modify the list to add more property.
the values would be save as the same name as the poperty i.e.value for angle would be stored in PatternAngle variable
Hope this helps
Thanks. I have cobbled together a lisp routine to change the layer etc to match a picked hatch so I can repeat that hatch exactly without having to set everything manually each time, but my routine below doesn't set the layer as desired and I can't work out why. (It is supposed to reset the current layer but it doesn't seem to change for the hatch)
(defun c:hatchfrom ()
(vl-load-com)
(setq clay (getvar "clayer"))
(setq x (entsel "\nSelect hatch to repeat: "))
(command "layer" "S" (cdr (assoc 8 (entget (car x)))) "" )
(setq pname (vla-get-PatternName (vlax-ename->vla-object (car x))))
(setq pscal (vla-get-PatternScale (vlax-ename->vla-object (car x))))
(setq pangl (vla-get-PatternAngle (vlax-ename->vla-object (car x))))
(setvar "hpassoc" 1)
(command "-hatch" "P" pname pscal pangl)
(setvar "clayer" clay)
If I run the line (command "layer" "S" (cdr (assoc 8 (entget (car (entsel))))) "" ) and pick a hatch, it changes to that layer as expected, but it seems not to as part of this routine.
@Gordon_S wrote:On further testing, I'm not sure that any of it works as I thought it might - where have I gone wrong?
It looks like our old friend, the allow-for-finishing-the-command-before-you-go-on-to-reset-the-Layer thing, again....
(while (> (getvar 'cmdactive) 0) (command pause))
EDIT: And another thing: The PatternAngle property will be returned in radians, so to use it in a Hatch command, you'll need to convert that to degrees. One advantage of using (setvar 'hpang) for that, and using "" [Enter] to accept the default within the command, is that you don't need to make that conversion. And you don't need as many variables. E.g.:
(defun c:hatchfrom (/ clay hatchobj)
(vl-load-com)
(setq
clay (getvar 'clayer)
hatchobj (vlax-ename->vla-object (car (entsel "\nSelect hatch to repeat: ")))
(setvar 'clayer (vla-get-Layer hatchobj))
(setvar 'hpname (vla-get-PatternName hatchobj))
(setvar 'hpscale (vla-get-PatternScale hatchobj))
(setvar 'hpang (vla-get-PatternAngle hatchobj))
(setvar 'hpassoc 1)
(command "-hatch" "P" "" "" "")
(setvar 'clayer clay)
