Visual LISP, AutoLISP and General Customization
FIND LIST OF BLOCK NAMES THAT CAN BE PURGE
21 REPLIES 21
Message 1 of 22
amyyoyo1
1430 Views, 21 Replies
Hi, I am tring to wirte an lisp routin that will purge all purgeable blocks except for two other blocks. The routin I have now will search all blocks in the drawing but cann't seem to found any purgeable blocks can somebody help?
please and thanks!
here is the code :
(defun purgeBlock()
  (setq ss (ssget "x" (list (cons 0 "INSERT"))))
  (SETQ con1 0)
  (repeat (sslength ss)
  (SETQ ss2 (ssname ss con1))
    (setq ss1 (entget ss2))
    (setq ss3 (cdr (assoc 8 ss1)))
  (if (AND (/= ss3 "Operator_Logos_WS") (/= ss3 "Operator_Logos_PL"))
(command "-purge" "block" ss3 "n")
    (setq con1 (+ con1 1))
  (XRED)
  (princ)
21 REPLIES 21
Message 21 of 22
_gile
in reply to: amyyoyo1
May be this way is safer.
Load:
(defun gc:IsReferenced (bname / blk)
  (and
    (setq blk (tblobjname "BLOCK" bname))
    (setq blkRec (cdr (assoc 330 (entget blk))))
    (setq blkRefs (vl-remove nil (mapcar 'entget (gc:massoc 331 (entget blkRec)))))
    (vl-some 'vl-consp (mapcar '(lambda (x) (entget (cdr (assoc 330 x)))) blkRefs))
(defun gc:DeleteBlock (bname / blk)
  (vl-load-com)
  (vl-catch-all-apply
    (function
      (lambda ()
	(setq blk (vla-item
		    (vla-get-Blocks
		      (vla-get-ActiveDocument
			(vlax-get-acad-object)
		    bname
  (if blk
    (progn
      (vlax-for	o blk
	(if (= (vla-get-ObjectName o) "AcDbBlockReference")
	  (vla-Delete o)
      (vla-delete blk)
(defun PurgeAllBlocksExcept  (pat / blk name blst loop)
  (while (setq blk (tblnext "BLOCK" (not blk)))
    (if
      (and
	(not (wcmatch (strcase (setq name (cdr (assoc 2 blk)))) (strcase pat)))
	(< (cdr (assoc 70 blk)) 4)
       (setq blst (cons name blst))
  (setq loop T)
  (while (and loop blst)
    (setq loop nil)
    (foreach n blst
      (or (gc:IsReferenced n)
	  (progn
	    (gc:DeleteBlock n)
	    (setq blst (vl-remove n blst))
	    (setq loop T)
(defun gc:massoc (code alst)
  (if (setq alst (member (assoc code alst) alst))
    (cons (cdar alst) (gc:massoc code (cdr alst)))
 and run:
(gc:PurgeAllBlocksExcept "Operator_Logos_WS,Operator_Logos_PL")
If it still does not work it's not necessary to try changing theargument of an expression with each variable (whatever its type). This will never be a way to debug a code.
Gilles Chanteau
GileCAD
GitHub
Message 22 of 22
Kent1Cooper
in reply to: Kent1Cooper
My Insert-the-Special-Blocks-to-prevent-Purging-and-just-Purge-all-Blocks approach [so much shorter] can also be done as a function with an argument with a list of the special Block names, rather than as a command with a fixed set of names:
(defun PABE (blklist / entl cmde) ; = Purge All Blocks Except
  (setq
    entl (entlast); starting point for later in removing temporary Blocks
    cmde (getvar 'cmdecho)
  ); setq
  (setvar 'cmdecho 0)
  (foreach blk blklist
    (if (or (tblsearch "block" blk) (findfile (strcat blk ".dwg")))
      ; already in drawing or available in Support File Search Paths?
      (progn
        (command "_.insert" blk (getvar 'viewctr)); temporarily
        (while (> (getvar 'cmdactive) 0) (command ""))
      ); progn
    ); if
  ); foreach
  (repeat 3 (command "_.purge" "_block" "*" "_no")); or more than 3 if you prefer
  (while (setq entl (entnext entl)) (entdel entl)); remove temporary ones
  (setvar 'cmdecho cmde)
  (princ)
); defun
Usage:  (PABE '("SpecialBlock1" "SpecialBlock2" "SpecialBlock37"))
with as many Block names in the list as you like.
Kent Cooper, AIA
”Boost
