Visual LISP, AutoLISP and General Customization
FIND LIST OF BLOCK NAMES THAT CAN BE PURGE
21 REPLIES 21
Message 1 of 22
amyyoyo1
1404 Views, 21 Replies
Hi, I am tring to wirte an lisp routin that will purge all purgeable blocks except for two other blocks. The routin I have now will search all blocks in the drawing but cann't seem to found any purgeable blocks can somebody help?
please and thanks!
here is the code :
(defun purgeBlock()
  (setq ss (ssget "x" (list (cons 0 "INSERT"))))
  (SETQ con1 0)
  (repeat (sslength ss)
  (SETQ ss2 (ssname ss con1))
    (setq ss1 (entget ss2))
    (setq ss3 (cdr (assoc 8 ss1)))
  (if (AND (/= ss3 "Operator_Logos_WS") (/= ss3 "Operator_Logos_PL"))
(command "-purge" "block" ss3 "n")
    (setq con1 (+ con1 1))
  (XRED)
  (princ)
21 REPLIES 21
Message 2 of 22
hmsilva
in reply to: amyyoyo1
Hi amyyoyo1,
with (cdr (assoc 8 ss1)) You'll get the Layer name where the block is inserted.
"Operator_Logos_WS" and  Operator_Logos_PL are Layer names or block names?
If block names, perhaps something like this
(defun c:test ( / ADOC LST N)
  (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vlax-for blk	(vla-get-blocks aDoc)
    (if	(and
	  (eq :vlax-false (vla-get-islayout blk))
	  (eq :vlax-false (vla-get-isxref blk))
	  (if (vlax-property-available-p blk 'effectivename)
	    (setq n (vla-get-effectivename blk))
	    (setq n (vla-get-name blk))
      (if (and (not (member n lst))
	       (not (wcmatch n "Operator_Logos_WS,Operator_Logos_PL"))
	(setq lst (cons n lst))
  (if (> (length lst) 0)
    (foreach blk lst
      (command "-purge" "block" blk "n")
HTH
Henrique
Message 3 of 22
Gary_J_Orr
in reply to: hmsilva
In addition to Henrique's comments: If you can select it then it isn't purgable...
nice approach though... but, instead of using short form code and repeating the purge command for each member of the blk list, how about stretching the code out and creating a string instead which can then be passed to the purge command. then repeat that a couple of times to kill nested blocks as well:
(defun C:purgeBlock ( / aDoc n blkstr)
    (if	(and
      (progn
	(if (vlax-property-available-p blk "effectivename")
	(if (not (vl-member-if
		   '(lambda (Exception)
		      (wcmatch (strcase n) (strcase Exception))
		      );lambda
		   (list "Operator_Logos_WS" "Operator_Logos_PL")
		   );vl-member-if
		 );if test cond
	  (if blkstr
	    (setq blkstr (strcat blkstr "," n))
	    (setq blkstr n)
  (vlax-release-object aDoc)
  (repeat 3
    (command "-purge" "blocks" blkstr "n")
 Just a thought...
Gary J. Orr
(Your Friendly Neighborhood) CADD/BIM/VDC Applications Manager
http://www.linkedin.com/in/garyorr
aka (current and past user names):
Gary_J_Orr (GOMO Stuff 2008-Present); OrrG (Forum Studio 2005-2008); Gary J. Orr (LHB Inc 2002-2005); Orr, Gary J. (Gossen Livingston 1997-2002)
Message 4 of 22
paullimapa
To do it the old fashion way, change your line of code as others have already posted which incorrrectly retrieves the Layer Name:
To the correctly line of code which retrieves the block name:
(setq ss3 (cdr (assoc 2 ss1)))
Paul Li
IT Specialist
@The Office
Message 5 of 22
hmsilva
in reply to: Gary_J_Orr
@Anonymous wrote:
... how about stretching the code out and creating a string instead which can then be passed to the purge command. then repeat that a couple of times to kill nested blocks as well
Nicely done!
Henrique
Message 6 of 22
Kent1Cooper
(defun purgeBlock()
That seems to me to be going about it the wrong way.  It is finding all insertions of Blocks, and if any is not of the two particular Block names, trying to Purge its Block definition.  But it won't be able to Purge the definition of a Block that's inserted in the drawing.  It isn't going to find Blocks that are Purge-able, because those won't be inserted anywhere, and so won't be found by that (ssget) function.
I think what you want to do is to step through the Block definition table, and for each name of a Block that's defined, do:
(ssget "X" '((2 . "TheBlockName")))
to see whether there are any of them inserted.  If that returns nil, and TheBlockName isn't one of the special ones, then Purge that Block definition.
You'll need to make it a little more sophisticated if you need to account for effective names of dynamic Blocks, and it won't be able to Purge any that are not inserted on their own but are nested in other Block definitions, unless those other Blocks are also unused and Purged first.
Kent Cooper, AIA
Message 7 of 22
Gary_J_Orr
well thanks Henrique, but... I left out the error check before purging (in some world or other there may not be any blocks in the drawing except the exceptions so I should have enclosed the "(repeat..." within an "(if blkstr..." block
ReallyBigGrin
Gary J. Orr
Message 8 of 22
Kent1Cooper
Here's another thought:
Just Insert one of each of the two special Blocks, do a Purge of all Blocks regardless, maybe repeat the Purge a few times for nested Blocks, and then delete those two you just inserted.  All other unused Block definitions will be purged, but those two will still be available whether or not there were any insertions of them beforehand.  No (ssget)-ing, no evaluations of whether names match, nor of whether something is an Xref or other variant on the idea of a Block, no individual Block names or strings of names fed to Purge, no stepping through either a selection set or the Block table, etc.
Kent Cooper, AIA
Message 9 of 22
Gary_J_Orr
in reply to: Kent1Cooper
Kent,
I like it...
In our efforts to "help" and "spread the knowledge" we sometimes forget the simplest of things don't we? Of course there's always the possibility that the requested block has already been purged but... that solution gets straight to the point.
-Gary
Gary J. Orr
Message 10 of 22
Kent1Cooper
@Anonymous wrote:
.... Of course there's always the possibility that the requested block has already been purged but....
That possibility can be dealt with, at least to some degree, thus:
(defun C:PABE (/ entl cmde) ; = Purge All Blocks Except
  (setq
    entl (entlast); starting point for later in removing temporary Blocks
    cmde (getvar 'cmdecho)
  ); setq
  (setvar 'cmdecho 0)
  (foreach blk '("SpecialBlock1" "SpecialBlock2"); add as many as you like
    (if (or (tblsearch "block" blk) (findfile (strcat blk ".dwg")))
      ; already in drawing or available in Support File Search Paths?
      (command "_.insert" blk (getvar 'viewctr) "" "" ""); temporarily
    ); if
  ); foreach
  (repeat 3 (command "_.purge" "_block" "*" "_no")); or more than 3 if you prefer
  (while (setq entl (entnext entl)) (entdel entl)); remove temporary ones
  (setvar 'cmdecho cmde)
  (princ)
); defun
That will even bring back in any of those special Blocks that's been Purged, as long as it's somewhere among the Support File Search Paths.  And it won't matter how many are in the list, or how many of them [if any] it couldn't find.
Kent Cooper, AIA
Message 11 of 22
hmsilva
    ); if
  ); foreach
Message 12 of 22
Gary_J_Orr
Kent, wouldn't your entnext calls have a problem with grabbing subentities? Don't ya think?
Back up to your insert function and add the main entities that you insert in the foreach loop to a selection set using entlast after each insertion, then delete the selection set by passing it to the erase command after the purge command...
Just a thought...
Gary J. Orr
Message 13 of 22
amyyoyo1
Hi hmsilva,
Operator_Logos_WS and  Operator_Logos_PL are block names I must had mess up the layer name and block name.
Thank you for your help the lisp rotine work really good.
Message 14 of 22
amyyoyo1
Hi Gary,
Thank you for your help, but the code seem to run into an error.
error:Function cancelled is the error message.
I am tring to cut down the runing time for the routine too. It's taking 2 to 3 mins to run though now.
Message 15 of 22
Kent1Cooper
@Anonymous wrote:
Kent, wouldn't your entnext calls have a problem with grabbing subentities? ....
In the context, since everything after the initial base-reference 'entl' object [the last thing before the routine begins] would be a Block insertion, (entnext) finding subentities would be possible only if a Block contains Attributes.  [It's not about the Block definition subentity pieces, which you can step through via (entnext) only by digging in with (tblobjname).]  In a quick experiment, I find the deletion part isn't bothered by that -- the (while ....) bit successfully removes the Blocks and their Attributes, without any problems.  However, if any Special Blocks might contain Attributes with non-constant values, the Insertion part of it would need to account for that possibility.  Since they're being inserted only temporarily to make them non-Purge-able, no specific answer(s) to the Attribute prompt(s) would be needed, and Enter would do:
  (setq
  ); setq
  (setvar 'cmdecho 0)
      (progn
        (command "_.insert" blk (getvar 'viewctr)); temporarily -- ends with insertion point, leaves asking for X scale
        (while (> (getvar 'cmdactive) 0) (command "")); default scales, rotation, Enter for any Attribute(s)
      ); progn
    ); if
  ); foreach
  (princ)
); defun
Kent Cooper, AIA
Message 16 of 22
_gile
Some times ago, I wrote some LISP routines to evaluate if a block is referenced, get all references of a block definition and purge all unreferenced blocks (even nested).
The original thread at TheSwamp.
The LISP code
;; gc:GetReferences
;; Returns the unerased block reference list for the block
;; Arguments
;; bname: block name
;; flag:  sum of the following binary codes
;;  1 = nested in blocks
;;  2 = inserted in model space
;;  4 = inserted in paper space
(defun gc:GetReferences    (bname flag / blk refs elst)
  (if
    (and
      (setq blk (tblobjname "BLOCK" bname))
      (setq refs (vl-remove-if-not
           'cdr
           (mapcar
             (function
               (lambda (x)
             (if (setq elst (entget x))
               (cons x (entget (cdr (assoc 330 elst))))
             (gc:massoc 331 (entget (cdr (assoc 330 (entget blk)))))
     (if (= 7 flag)
       (mapcar 'car refs)
       (if (< 0 flag 7)
     (mapcar 'car
         (vl-remove-if
           (function
             (lambda (x)
               (wcmatch    (strcase (cdr (assoc 2 (cdr x))))
                (cond
                  ((= 1 flag) "`**_SPACE*")
                  ((= 2 flag) "~`*MODEL_SPACE")
                  ((= 3 flag) "`*PAPER_SPACE*")
                  ((= 4 flag) "~`*PAPER_SPACE*")
                  ((= 5 flag) "`*MODEL_SPACE*")
                  ((= 6 flag) "~`**_SPACE*")
           refs
;; gc:IsReferenced
;; Evaluates if the block is referenced
;; Argument
(defun gc:IsReferenced (bname / blk)
  (and
    (setq blkRec (cdr (assoc 330 (entget blk))))
    (setq blkRefs (vl-remove nil (mapcar 'entget (gc:massoc 331 (entget blkRec)))))
    (vl-some 'vl-consp (mapcar '(lambda (x) (entget (cdr (assoc 330 x)))) blkRefs))
;; gc:PurgeBlock
;; Purges the blocks which names matches with tha pattern
;; Argument
;; pat: pattern (wildcard patterns allowed, not case sensitive)
(defun gc:PurgeBlock (pat / blk name elst blst loop)
  (vl-load-com)
  (while (setq blk (tblnext "BLOCK" (not blk)))
    (if
      (and
    (wcmatch (strcase (setq name (cdr (assoc 2 blk)))) (strcase pat))
    (< (cdr (assoc 70 (setq elst (entget (tblobjname "BLOCK" name))))) 4)
       (setq blst (cons (cdr (assoc 330 elst)) blst))
  (setq loop T)
  (while (and loop blst)
    (setq loop nil)
    (foreach b blst
      (or (vl-some 'entget (gc:massoc 331 (entget b)))
      (progn
        (setq blk (vlax-ename->vla-object b))
        (vlax-for o    blk
          (if (= (vla-get-ObjectName o) "AcDbBlockReference")
        (vla-Delete o)
        (vla-delete blk)
        (setq blst (vl-remove b blst))
        (setq loop T)
;; gc:massoc
;; Returns the list of all values for the specified group code in an association list
;; Arguments
;; code: group code
;; alst: association list
(defun gc:massoc (code alst)
  (if (setq alst (member (assoc code alst) alst))
    (cons (cdar alst) (gc:massoc code (cdr alst)))
Gilles Chanteau
GileCAD
GitHub
Message 17 of 22
Gary_J_Orr
it was "quick and dirty" code in the first place...
It ran quick and clean when I created a test drawing to run it in but...
If it's taking a long time to process then your block count must be huge and you should perhaps try Kent's "insert then delete" suggestion as it wouldn't have to loop through the list of blocks...
I also didn't include anything to address any potential language issues (I don't know if that is involved in the cancelling of the function or not)
(command "_-purge" "_blocks" blkstr "_n")
There is also the possibility that the list of defined blocks in your drawing is simply too long for the command to accept.
Again, Kent has posted a pretty clean alternate method that you should perhaps try.
-Gman
Gary J. Orr
Message 18 of 22
amyyoyo1
Thank you again, I have around 143 blocks in total I think that may be a bit too much for the command line.
I'll try Kent code and see if It will run faster.
Message 19 of 22
_gile
You can try this, adapted from the upper routines
;; gc:PurgeAllBlocksExcept
;; Purges all the blocks which names do not matches with the pattern
;; Argument
(defun gc:PurgeAllBlocksExcept (pat / blk name elst blst loop)
  (vl-load-com)
    (if
      (and
	(not (wcmatch (strcase (setq name (cdr (assoc 2 blk)))) (strcase pat)))
  (setq loop T)
    (setq loop nil)
    (foreach b blst
	  (progn
	    (vlax-for o	blk
		(vla-Delete o)
	    (vla-delete blk)
	    (setq loop T)
;; gc:massoc
;; Arguments
;; code: group code
 Then run:
(gc:PurgeAllBlocksExcept "Operator_Logos_WS,Operator_Logos_PL")
Gilles Chanteau
GileCAD
GitHub
Message 20 of 22
amyyoyo1
in reply to: _gile
I ran your code and given me an error that said error:automation error. object is referenced , so I look into it and changed (vl-some 'entget (gc:massoc 331 (entget b))) to (vl-some 'entget (gc:massoc 331 (entget blst))) but that also give me an error, then I changed to (vl-some 'entget (gc:massoc 331 blst)) still not working.
the error message said: bad association list__________________then a long list of entity name:
”Boost
