Visual LISP, AutoLISP and General Customization
Find current lisp file path
8 REPLIES 8
Message 1 of 9
4195 Views, 8 Replies
Hi All,
Is there any way to find the path of current lisp file. For example,If we located test.lsp file on C driver, the function will return "C:\test.lsp".etc...
Thanks for any help.
8 REPLIES 8
Message 2 of 9
Lee_Mac
What do you mean by 'current lisp file'?
Message 3 of 9
(findfile "yourfile.lsp") in autocad will return the location of "yourfile" within the autocad search paths, if it exists...
hopefully that helps
Message 4 of 9
Thanks for reply. But I want to find the saved path of lisp file being edited. I want to load other file in same folder which located anywhere.Maybe it's not loacted in Autocad search path.
Message 5 of 9
bgingerich
There may be a way to retrieve the "last opened file" location from a registery entry somewhere?  I only have LT at the moment, so I can't help you with the actual entry.
This is the folder for recent files in 2010 LT.  May or may not help you...
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD LT\R15\ACADLT-8001:409\Recent File List
HTH
Brandon Gingerich
Message 6 of 9
Lee_Mac
If you are referring to a LISP file that is being edited within the Visual LISP IDE, you could read the *edit-file-history* section of the VLIDE.DSK file.
Message 7 of 9
wdwolff1
Hello, have you find athe solution.
i am also looking for it.
if you found a solution can you mail me?
email: wdwolff@planet.nl
Message 8 of 9
Moshe-A
in reply to: wdwolff1
@wdwolff1 hi,
i googled and the only solution i found for knowing the full path of lisp file comes from dos_lib.
1. install >> mcneel doslib << on your autocad
2. on each source lisp file set an id something like (setq MY_LISP_ID "MyLispID.lsp")
3 . call the following nice function.
be aware for the file type. if you are compiling the lsp to fas or vlx.
also note there could be 2 lsp files with the same name coming from different folders.
enjoy
Moshe
(defun get_fullpath_lispname (fname / modula)
 (cond
  ; make sure doslib is loaded
  ((null (member (setq modula (strcat "doslib" (substr (getvar "acadver") 1 2) "x64.arx")) (arx))
   (prompt (strcat "\n" modula " is not loaded."))
  ); case
  ((vl-some
     (function
       (lambda (fpath)
         (if (eq (strcase (strcat (vl-filename-base fpath) (vl-filename-extension fpath))) (strcase fname)) fpath)
    (dos_lisplist t)
  ); case
 ); cond
); get_fullpath_lispname
Message 9 of 9
john.uhden
@Anonymous
I'm sorry, but as I recall there is no way using AutoLisp to find the path of a loaded lisp file.
Owen Wengerd (Manusoft) used to provide us a VLXLOAD.arx to snag the name/path of a VLX file when it's loaded but I don't know if he has provided same for newer releases (since about 2006).
John F. Uhden
”Boost
