Visual LISP, AutoLISP and General Customization
FIND and REPLACE texts contents of Multileader.
6 REPLIES 6
2466 Views, 6 Replies
Hi- Could anyone tell me how to FIND and REPLACE texts contents of Multileader.
I am trying to change key notes for “M-A” to “M-1”.
The usual “_find” command does not pick up these attributes.
Tried using Revup.lsp but says it is invalid as it needs to be inserted.
Please advice!
6 REPLIES 6
Ajilal.Vijayan
While using FIND command, make sure these check boxes are selected
See the image in here
Spoiler
in reply to: Ajilal.Vijayan
Thank you for the advice. It worked!!Smiley Happy
Also would you know anything about FIND and REPLACE command when they are more than a single line?
For example I want to change all T=10mm to T=5mm.
In the _find command, it only lets me type the first line, GLASS.
I want to be able to find the specific description rather than looking through all.
FILTER also doesn’t seem to filter through the text contents of the attribute.
Would really appreciate your advice once again.
Ajilal.Vijayan
I dont think FIND command will allow you type more than 1 line.
Why dont you type T=10mm at the find box and T=5mm at the replace box ?
If you dont want to search the entire drawing  there is a 'Find where' selection at the right top corner of FIND command.
Um is that really the solution? Because i dont see it working on my mleader text?
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
hmsilva
in reply to: ceethreedee.com
Hi ceethreedee.com,
I'm not a C3D guy, therefore I don't have C3D to test, but in AutoCAD 2016, It works as expected.
If it's possible, attach a sample dwg please.
Henrique
MSchille-1994
This does not work in Civil 3D 2022 either.
Attitude, not Aptitude, Determines Altitude
”Boost
