Find and replace text
zasanil
Message 1 of 23
zasanil
I've searched around and found a couple lisps that would find text and replace them (without a dialog). One exmple is from this forum post here: http://forums.augi.com/showthread.php?43053-Take-existing-drawings-and-find-all-quot-quot-and-replac... I have copied the code it below. I wanted to see if anyone could modify it to also find text inside of tables also which it doesn't seem to do.
Thanks!
; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities
; that have a Find$ string with a Replace$ string.
; Arguments: 2
;   Find$ = Phrase string to find
;   Replace$ = Phrase to replace it with
; Syntax: (FindReplaceAll "old string" "new string")
; Returns: Updates Text, Mtext, Dimension and Attribute Block entities
(defun c:FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt#
  DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace:
  Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$)
  ; FindReplace: - Returns Str$ with Find$ changed to Replace$
  ; Arguments: 3
  ;   Str$ = Text string
  ;   Replace$ = Phrase to replace Find$ with
  ; Returns: Returns Str$ with Find$ changed to Replace$
  (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#)
    (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$))
    (while Loop
      (setq Mid$ (substr NewStr$ Cnt# FindLen#))
      (if (= Mid$ Find$)
        (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#)))
              Cnt# (+ Cnt# ReplaceLen#)
        );setq
        (setq Cnt# (1+ Cnt#))
      );if
      (if (= Mid$ "") (setq Loop nil))
    );while
    NewStr$
  );defun FindReplace:
  ; Start of Main function
  (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ ""))
    (progn
      (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>"))))
        (progn
          (command "UNDO" "BEGIN")
          (setq Cnt# 0)
          (repeat (sslength SS&)
            (setq EntName^ (ssname SS& Cnt#)
                  EntList@ (entget EntName^)
                  EntType$ (cdr (assoc 0 EntList@))
                  Text$ (cdr (assoc 1 EntList@))
            );setq
            (if (= EntType$ "INSERT")
              (if (assoc 66 EntList@)
                (progn
                  (while (/= (cdr (assoc 0 EntList@)) "SEQEND")
                    (setq EntList@ (entget EntName^))
                    (if (= (cdr (assoc 0 EntList@)) "ATTRIB")
                      (progn
                        (setq Text$ (cdr (assoc 1 EntList@)))
                        (if (wcmatch Text$ (strcat "*" Find$ "*"))
                          (progn
                            (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$))
                            (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@))
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                    (setq EntName^ (entnext EntName^))
                  );while
                );progn
              );if
                (progn
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
          (command "UNDO" "END")
        );progn
      );if
    );progn
  );if
  (princ)
);defun FindReplaceAll
Dan Nicholson C.I.D.
PCB Design Engineer
Replies (22)
Message 2 of 23
devitg
Please upload your dwg, where to apply
Message 3 of 23
zasanil
Hi there,
Attached is an example drawing. I basicaly want to be able to do what the "FIND" command in autcad does where it will replace a text string with another text string. It would look at every text string in the drawing and replace it. It could be in blocks, nested blocks, tables, text, mtext, attributes, etc. The code I found above works on some items but not all (Not like the "FIND" command).
I'm really after a routine I can incorporate into my lisp program that would act as a function where I could have:
(c:FindReplaceText "old string" "new string")
Thanks!
PCB Design Engineer
Message 4 of 23
devitg
Please state a true old string newstring at the dwg sample
Message 5 of 23
zasanil
In the example I posted, the oldstring would equal "xxxxxx" and would be replaced by the newstring "900999"
PCB Design Engineer
Message 6 of 23
CADaSchtroumpf
With this, it seem to do work in object ACAD_TABLE
(defun my_replace_text (new_string old_string / js n ename)
  (vl-load-com)
  (defun string-subst (nam_obj / value_string nbs tmp_nbs)
    (setq value_string (vlax-get nam_obj 'TextString) nbs 0)
    (while nbs
      (if (setq nbs (vl-string-search old_string value_string (setq tmp_nbs nbs)))
        (setq
          value_string (vl-string-subst new_string old_string value_string tmp_nbs)
          nbs (1+ nbs)
    (vlax-put nam_obj 'TextString value_string)
  (defun tabl_subst (obj / eRows eColumns R C val nbs tmp_nbs)
    (setq
      eRows (vla-get-rows obj)
      eColumns (vla-get-columns obj)
      R 0
    (repeat eRows
      (setq C 0)
      (repeat eColumns
        (setq val (vla-GetText obj R C) nbs 0 tmp_nbs nil)
        (while nbs
          (if (setq nbs (vl-string-search old_string val (setq tmp_nbs nbs)))
            (setq
              val (vl-string-subst new_string old_string val tmp_nbs)
              nbs (1+ nbs)
        (vla-SetText obj R C val)
        (setq C (+ C 1))
      (setq R (+ R 1))
  (setq js
    (ssget "_X"
        (-4 . "<OR")
          (0 . "*TEXT,MULTILEADER,ATTDEF,ACAD_TABLE")
          (-4 . "<AND")
            (0 . "INSERT") (66 . 1)
          (-4 . "AND>")
        (-4 . "OR>")
  (cond
    (js
      (repeat (setq n (sslength js))
        (setq ename (vlax-ename->vla-object (ssname js (setq n (1- n)))))
        (cond
          ((vlax-property-available-p ename 'TextString)
            (string-subst ename)
          ((vlax-property-available-p ename 'Rows)
            (tabl_subst ename)
          (T
            (mapcar
              '(lambda (att)
                (string-subst att)
              (vlax-invoke ename 'GetAttributes)
  (prin1)
Use (my_replace_text "900999" "xxxxxx")
This syntax can be used in a script for multiples drawings...
Message 7 of 23
zasanil
Hi CADAStroumph,
That does work great for tables and attributes. Would it be easy to adjust it so it will search and replace in blocks / nested blockes also? I think thats one of the only peices I'm missing.
Thanks!
PCB Design Engineer
Message 8 of 23
CADaSchtroumpf
You can try, just work's with attribut in nested blocks, after is hard to me to continue in nested block for table or other.
(defun my_replace_text (new_string old_string / js n ename first_blk l_blk n_blk)
  (vl-load-com)
  (defun xplore (l / ent cnt msg)
    (setq ent (entget (cdr (assoc -2 l))) cnt 0)
    (cond
      ((eq (cdr (assoc 0 ent)) "INSERT")
        (mapcar
          '(lambda (att)
            (string-subst att)
          (vlax-invoke (vlax-ename->vla-object (cdar ent)) 'GetAttributes)
        (while (setq ent (entnext (cdar ent)))
          (setq ent (entget ent))
          (if (eq (cdr (assoc 0 ent)) "INSERT")
            (progn
              (setq cnt (1+ cnt))
              (repeat cnt
                (mapcar
                  '(lambda (att)
                    (string-subst att)
    (while nbs
        (setq
          nbs (1+ nbs)
    (setq
      R 0
    (repeat eRows
      (setq C 0)
      (repeat eColumns
        (while nbs
            (setq
              nbs (1+ nbs)
        (setq C (+ C 1))
      (setq R (+ R 1))
  (setq first_blk (tblnext "BLOCK" T))
  (cond
    (first_blk
      (setq l_blk (list first_blk))
      (while (setq n_blk (tblnext "BLOCK"))
        (setq l_blk (cons n_blk l_blk))
      (foreach n l_blk
        (if (/= (logand (cdr (assoc 70 n)) 4) 4)
          (if (/= (logand (cdr (assoc 70 n)) 16) 16)
            (xplore n)
  (setq js
    (ssget "_X"
        (-4 . "<OR")
          (-4 . "<AND")
          (-4 . "AND>")
        (-4 . "OR>")
  (cond
    (js
        (cond
            (tabl_subst ename)
          (T
            (mapcar
              '(lambda (att)
                (string-subst att)
  (prin1)
Message 9 of 23
CADaSchtroumpf
Don't forget to execute REGENALL at the end of the procedure to see the changes...
Message 10 of 23
zasanil
Thank you for your help CADStroumph! I appriciate it.
PCB Design Engineer
Message 11 of 23
David125
For people who have not done coding in a long long time, where do I incorporate my input for the text I want to replace?
Message 12 of 23
Kent1Cooper
The word after (defun at the top is the function name.  The things after the left parenthesis following that and before the slash are the arguments that need to be supplied.  So to use it, type in a left parenthesis followed by the function name followed by values for the arguments [which in this case must be text strings] followed by a right parenthesis.  Note the order of the arguments.  To replace "that" [the old string] with "this" [the new string]:
(my_replace_text "this" "that")
Kent Cooper, AIA
Message 13 of 23
Designer-Drafter_Joe
Hello!  I have tried this code and I get an error before it does anything, which is "; error: Automation Error. Currently write protected".  Does anyone know what this means?  I've used other code to do the same thing but the result is the same as this.
Thank you for your time!
Drafter_Joe
Message 14 of 23
ec-cad
The error is due to 'something' in the vl portion of the code. You don't say 'which' Code you are using,
so it's hard to determine. Perhaps it is finding the target text is within a Dynamic block or a Dim that
is not 'changeable' .. or is write-protected.
ECCAD
Message 15 of 23
Hello ec-cad,
You are correct, I did not identify which of the 3 codes I was referring to.  I tried all three of them and got the same response.  I suppose I need code that disregards whatever text is found that is write-protected.  Unfortunately, I don't know Visual LISP, and I don't have any reference materials to help.  Might you, or someone else, have some example code that I can learn from?
Thank you!!
Drafter_Joe
Message 16 of 23
ec-cad
Drafter_Joe. What I do with the 'tough' ones, is set a variable to 0 atop the lisp file,
then down the program, insert (setq variable 1) or 2, 3. etc. to get an idea of the 'area' in code
that is failing. Error trapping can also be used, or vl-catch-all-apply (search for that here) , or use VLIDE and step through
the code. Try the first approach using the Test.lsp attached. At Command Prompt, type !FLAG to find
the next #, that should be the area of concern.
I don't know of a way to capture that 'write-protect' error and have it recover.
ECCAD
Message 17 of 23
ECCAD, That makes very good sense, great tip! Thank you! I will give your suggestion a try very soon and let you know the results. Incidentally, I found another LISP routine that did work, called "srxText" from CAD Studio, it's mentioned above in this post. Thank you again!
Message 18 of 23
ec-cad
Good Luck.
Glad you found a solution.
Cheers.!
ECCAD
Message 19 of 23
Well, I didn't finish that like I thought I did, started to mention a "But," deleted it and sent my reply without noticing.  Anyway, it works well, but it's an executable, .vlx program, can't use as a subroutine to have it run multiple times in a row like with the other ones in this thread.  Again, I'll report back on any progress.
Thank you!
Drafter_Joe
Message 20 of 23
ec-cad
Sure, you (can) run it multiple times. You load it, run it. That yields a 'last' command.
You just hit the Enter key after making the first run, then hit the Enter key to repeat
that last command.
ECCAD
