Valued Contributor
bdsmls
Message 1 of 16 (1,604 Views)
Find and replace multileader text with LISP
1604 Views, 15 Replies
01-25-2012 09:15 AM
I'm looking for a lisp routine that can find and replace multileader text.
I want to replace "T." with "T+" and "B." with "B+".
All the multileaders are on layers with a suffix of "-elev".
Any help will be greatly appreciated.
Thanks in advance,
Larry
pbejse
Message 2 of 16 (1,585 Views)
Re: Find and replace multileader text with LISP
01-26-2012 03:07 AM in reply to: bdsmls
Thanks in advance,
Larry
command:  _find
settings....
Text types
Dimension/Leader text
Why the need for lisp codes?
Anyway, since i'm replying.
(defun c:REpME  (/ sel e)
      (setq sel (ssget "_X" '((0 . "MULTILEADER")(8 . "*-elev"))))
      (repeat (sslength sel)
            (setq e (vlax-ename->vla-object (ssname sel 0)))
            (vla-put-textstring
                  e
                  (vl-string-translate
                        "B.T."
                        "B+T+"
                        (vla-get-textstring e)))
            (ssdel (ssname sel 0) sel)
HTH
pbejse
Message 3 of 16 (1,580 Views)
01-26-2012 05:14 AM in reply to: pbejse
Scratch the previous post
This is more specific:
      (if (setq sel (ssget '((0 . "MULTILEADER")(8 . "*-elev"))))
	                   str (vla-get-textstring e))
	            (if (setq f
		            (cond
		            	((wcmatch str "*B.*") (list "B." "B+"))
			        ((wcmatch str "*T.*") (list "T." "T+"))))
			(vla-put-textstring e
	                (vl-string-subst (cadr f)(car f) str) )
          (princ)
Valued Contributor
bdsmls
Message 4 of 16 (1,566 Views)
01-26-2012 09:34 AM in reply to: bdsmls
That's what i was looking for. Thanks for your help.
Larry
Valued Mentor
alanjt_
Message 5 of 16 (1,561 Views)
01-26-2012 01:19 PM in reply to: pbejse
@pbejse: FYI, wcmatch IS case sensitive.
pbejse
Message 6 of 16 (1,557 Views)
01-26-2012 09:27 PM in reply to: alanjt_
You are absolutely right.. my mistake :smileywink:
Thanks Alanjt.....
bbarkman.jedson
Message 7 of 16 (1,295 Views)
10-08-2012 12:58 PM in reply to: bdsmls
Would this work if a block with an attribute is embedded in the multileader?
pbejse
Message 8 of 16 (1,283 Views)
10-08-2012 08:14 PM in reply to: bbarkman.jedson
Yes i think its possible, what do you have in mind?
bbarkman.jedson
Message 9 of 16 (1,262 Views)
10-09-2012 06:12 AM in reply to: pbejse
Our revision tag is a block embedded in a multileader with the one attribute (REVNUM). I am prompting the user for the current revision letter/number (so the routine knows which values to look for) and the desired revision. I'd like to check the current value from the user against what's in the multileader. If there's a match, change it. If not, do nothing. In the same routine I'm also looking at regular blocks via the attribute name. That way if a block or multileader with that block is inserted they all get checked. When the attribute tag name is found the routine proceeds accordingly. This works fine with regular blocks. The only thing missing is the "if" action for multileaders. They get changed no matter what, which means a revision tag could be altered when it shouldn't. The current code is attached. Much of it was provided by Lee McDonnell.
bbarkman.jedson
Message 10 of 16 (1,260 Views)
10-09-2012 06:14 AM in reply to: bdsmls
Here's the code.
