It works either way, or by any valid way of making the List, except that the arguments need to be in a different order [list before position number]....
Command: ( FLOLI 2 sl "D" )
; error: bad argument type: listp 2
Command: ( FLOLI sl 2 "D" )
(("1" "D") ("2" "D"))
It even works if not all the sub-lists have "enough" items in them:
Command: (setq sl '((3 4 5) ("yes" 3 8 pi) (89.2 4 "whatever") (T "this" "that" 4)))
Command: (floli sl 4 4)
((T "this" "that" 4))
But if it matters, I found, in experimenting with the same list, that if pi is the element in a list that you're filtering for, you have to "do it right" with a preceding apostrophe to get what you want:
Command: (floli sl 4 pi)
nil
But:
Command: (floli sl 4 'pi)
(("yes" 3 8 PI))
That's not required with the symbols T or nil as elements in the sub-lists. I'm not sure whether there might be other things that would require some kind of special handling, as pi does.
Kent Cooper
stevor wrote...
Seems to work with the input list trewritten to lake lists:
(setq sl ( list (list "1" "X") (list"1" "D") (list "2" "D") ) ) ; input list
(setq rl ( FLOLI 2 sl "D" ) ) ; result list
Kent Cooper, AIA
