There is no such thing as a user.pgp. Only one Acad.pgp. If the users want
custom shortcut keys, and you don't want them mucking in the Acad.pgp, you
must use lisp to do it. As an alternative, the user can place a copy of the
Acad.pgp in a folder that is higher in the search path, so it is found and
executed first.
BTW, pgp load first, AFAIK.
R. Robert Bell
"Jason Wilder" wrote in message
news:4050cf57_1@newsprd01...
Can anyone point me to some sites, or tell me where I can get the
information on what the load sequences are for standard AutoCAD files?
Such as, at what point does the PGP file load? Before or after LSP files?
Also, a something I forgot, can a second PGP file be loaded? Some users
have different command aliases they want to use, but instead of them editing
the local PGP file, which could be deleted or otherwise, I watned to just
create a separate PGP (i.e. username.PGP) that I could autoload w/ the
office customization LISP file.
I'm looking to eliminate as much 'local' customization' as possible, by
setting up so the users have personalized PGP/MNU/LSP that is on the
network, so it isn't lost when a machine crashes or I upgrade the software.
Thanks.
