Extract Layers...
7 REPLIES 7
Message 1 of 8
1029 Views, 7 Replies
Extract Layers...
How can I extract all layers in an open drawing to a notepad or txt file? TIA
7 REPLIES 7
Message 2 of 8
gjrcmb
Thanks to Lynn Allen on her recent video posting on a reminder on how to "Print a List of Your Layers" at http://www.cadalyst.com/video
Open Layer Manager, select All Layers (Ctrl-A), Copy all layers with Ctrl-C.  Open Notepad or actually Excel is better and Paste.
OR
Enter -Layer at the command prompt, type ?, then *, and copy layer listing from Text Screen.
Message 3 of 8
Kent1Cooper
If you just want the Layer names written out to a file, here's one way:
(defun C:LLTF (/ lay); = Layer List To File
  (setq LLF (open "X:/Your/File/Path/And/Filename.txt" "w"))
  (while (setq lay (tblnext "layer" (not lay)))
    (write-line (cdr (assoc 2 lay)) LLF)
  ); while
  (close LLF)
); defun
Kent Cooper, AIA
Message 4 of 8
gjrcmb
Oh, you want a lisp routine.  My oversight.  Smiley Embarassed
Message 5 of 8
in reply to: gjrcmb
Copy-Paste thing doesn't work in 2011... Thanks to all!
Message 6 of 8
Hallex
Mondo,
Try this lisp from my code library
Change to display properties as you need
~'J'~
Message 7 of 8
Kent1Cooper
in reply to: Kent1Cooper
You can have it include more information about the Layer, if you want.  For example, to put the values for:
LayerName ColorNumber Linetype
on each Layer's line in the resulting text file, do this:
(defun C:LLTF (/ LLF lay); = Layer List To File
    (write-line
      (strcat
        (cdr (assoc 2 lay)) " " ; name
        (itoa (cdr (assoc 62 lay))) " " ; color
        (cdr (assoc 6 lay)); linetype
      ); strcat
      LLF
    ); write-line
  ); while
  (close LLF)
); defun
Kent Cooper, AIA
Message 8 of 8
How to import back the exported file to AutoCAD and read modified items? TIA
”Boost
