I got the code form website, but i forget the site.
Brief info of the code : Gets a application name of Xdata attached in drawing and process the Xdata related the application name and export it to excel file.
The problem: Export is limited to first three column, attached Image1 shows the Xdata attached with Auto cad Entity and Image2 shows the Exported excel file and there notice the Column No 4 and 5 are not exported.
Could any one help to fix this below code, Attached Dwg file for Reference.
(defun C:WXD (/
appname
col
data
en
header
item_list
obj
result
row
spec_list
ss
xdv
xlapp
xlbook
xlbooks
xlcells
xlsheet
xlsheets) ;write xdata to Excel
;; main part
(setq result nil)
(setq appname (getstring T
"\nEnter the name of extension application (case-nonsensitive): "))
(setq ss (ssget "_X" (list (list -3 (list appname)))))
(while (setq en (ssname ss 0))
(setq obj (vlax-ename->vla-object (ssname ss 0)))
(vla-getXdata
obj
appname
'xtp
'xdv
(setq data
(mapcar 'vlax-variant-value
(vlax-safearray->list xdv)
(setq spec_list (cons (list (cadr data) (caddr data) (cadddr data))
spec_list))
(ssdel en ss))
;; Excel part
(or (vl-load-com))
(alert "Just Close Excel, Nothing Else")
(setq xlApp (vlax-get-or-create-object "Excel.Application")
xlBooks (vlax-get-property xlApp "Workbooks")
xlBook (vlax-invoke-method xlBooks "Add")
xlSheets (vlax-get-property xlBook "Sheets")
xlSheet (vlax-get-property xlSheets "Item" 1)
xlCells (vlax-get-property xlSheet "Cells")
(vla-put-visible xlApp :vlax-true)
(setq row 1)
(setq col 1)
(setq header '("Column1" "Column2"));<-- change header names to your suit
(repeat (length header)
(vlax-put-property
xlCells
"Item"
row
col
(vl-princ-to-string (car header))
(setq header (cdr header))
(setq col (1+ col))
(setq row 2
col 1
(repeat (length spec_list)
(setq item_list (car spec_list))
(repeat (length item_list)
(vlax-put-property
xlCells
"Item"
row
col
(vl-princ-to-string (car item_list))
(setq item_list (cdr item_list))
(setq col (1+ col))
(setq spec_list (cdr spec_list))
(setq col 1
row (1+ row)
(vlax-invoke-method
xlBook
'SaveAs
(strcat (getvar "dwgprefix")
(vl-string-right-trim ".dwg" (getvar "dwgname"))
-4143
nil
nil
:vlax-false
:vlax-false
1
2
(vlax-release-object xlCells)
(vlax-release-object xlSheet)
(vlax-release-object xlSheets)
(vlax-release-object xlBook)
(vlax-release-object xlBooks)
(vlax-release-object xlApp)
(setq xlApp nil)
(gc)
(gc)
(princ)
(princ "\nStart command with WXD...")
(princ)
Solved by dbroad. Go to Solution.
Always add the source as a comment to your code so that you can both give credit and find it again. It is an extremely easy search to find. http://forums.augi.com/archive/index.php/t-84767.html
Just change the line commented for headers to use the header names and the number of headers you want.
(defun C:WXD (/
appname
col
data
en
header
item_list
obj
result
row
spec_list
ss
xdv
xlapp
xlbook
xlbooks
xlcells
xlsheet
;; main part
(setq result nil)
(vla-getXdata
obj
appname
'xtp
'xdv
(setq data
(setq spec_list (cons (cdr data) spec_list)) ;;<-This line was limiting the output to 3 items each.
(ssdel en ss))
;; Excel part
(or (vl-load-com))
(setq row 1)
(setq col 1)
(setq header '("Column1" "Column2" "Column3" "Column4""Column5"));<-- change header names to your suit
(vlax-put-property
xlCells
"Item"
row
col
(setq col (1+ col))
(setq row 2
col 1
(vlax-put-property
xlCells
"Item"
row
col
(setq col (1+ col))
(setq col 1
row (1+ row)
(vlax-invoke-method
xlBook
'SaveAs
-4143
nil
nil
:vlax-false
:vlax-false
1
2
(setq xlApp nil)
(gc)
(gc)
(princ)
(princ)
Try this
How would you add area measurements to this lisp for each layer?
