Visual LISP, AutoLISP and General Customization
Explode method on MINSERTs ???
9 REPLIES 9
Message 1 of 10
1270 Views, 9 Replies
Should work if you trust vlax-method-applicable-p (I don't think you
should).
For example:
_$ (setq im (vlax-ename->vla-object (car(entsel))))
_$ (vlax-method-applicable-p im 'Explode)
T
_$ (vla-explode im)
; error: Automation Error. Cannot explode entity
_$ (vlax-invoke-method im 'Explode)
Is it just another bug, or I'm missing something?
TIA,
Reinaldo Togores
Graphics Expression in Engineering-CAD Research Group
University of Cantabria, Spain.
Personal WebSite: http://personales.unican.es/togoresr/
9 REPLIES 9
Message 2 of 10
"R. Togores" wrote in message
news:6BF8895572DA7346778FD015FB07A2F4@in.WebX.maYIadrTaRb...
> should).
> For example:
> T
> _$ (vla-explode im)
> TIA,
> Reinaldo Togores
Reinaldo,
Aunque en el manual dice que si es posible explotar "minsert block" via
vla-explode, no es posible ya que se contradice si lees lo correspondiente
al comando explode y la parte referente a minsert's.
Saludos,
Luis.
Even if the method is available and return T, Blocks inserted using MINSERT
cannot be exploded.
Message 3 of 10
I think that it inherits the explode method, because it is an insert, but
minserts can not be exploded. Bug, maybe. Help file omission, definitely.
Bobby C. Jones
> should).
> For example:
> T
> _$ (vla-explode im)
> TIA,
> Reinaldo Togores
Message 4 of 10
Gracias, Luis.
Me había saltado esa parte.
Decididamente, vlax-method-applicable-p sirve de bien poco.
Un saludo,
Reinaldo
"Luis Esquivel" escribió en el mensaje
news:2D6D8729A355F4A6C113459BC259B167@in.WebX.maYIadrTaRb...
> > should).
> > For example:
> > T
> > _$ (vla-explode im)
> > TIA,
> > Reinaldo Togores
> Reinaldo,
> Saludos,
> Luis.
MINSERT
> cannot be exploded.
Message 5 of 10
MInserts have never been able to be exploded, so this is as designed
behavior.
"Bobby Jones" wrote in message
news:0EB4947F3045895DFF6F3019BDA21781@in.WebX.maYIadrTaRb...
definitely.
> Bobby C. Jones
> > should).
> > For example:
> > T
> > _$ (vla-explode im)
> > TIA,
> > Reinaldo Togores
Message 6 of 10
I agree. I said maybe a bug, because the vlax-method-applicable-p should
return nil on a minsert instead of T. But it's definitely a shortcoming of
the help files to list the explode method as available to a minsert, when
clearly it is not. Does anyone know if this is fixed in TuTu?
Bobby C. Jones
"Art Cooney" wrote in message
news:C130F472F015CE870329AE48900162CB@in.WebX.maYIadrTaRb...
> behavior.
Message 7 of 10
Definitely vlax-method-applicable-p is a sorry contraption.
¿What's the use of a predicate if it you can't trust it?
Other example: GetBoundingBox on rays and xlines,
vlax-method-applicable-p will also return True on this objects
when clearly it is not applicable.
Although in this case the method should really be applicable and could
return 1.#INF,
as Reini Urban once suggested, which is the (also undocumented)
representation of
INFINITE (real number overflow)...
(try some real big number like 1.0e+310, you'll get 1.#INF)
Reinaldo
"Bobby Jones" escribió en el mensaje
news:FE80702D9DFD416F3A3C6CE47E7A87EF@in.WebX.maYIadrTaRb...
of
> Bobby C. Jones
> > behavior.
Message 8 of 10
The predicate can be trusted. The object has an exposed explode method.
vlax-method-applicable-p returns true if the object has an exposed method
with the name you pass it. The minsert block object has an explode method.
You can call that method and the object will respond. In this case the
object returns an exception telling you it cannot be exploded. This is not
what you wanted but it is as designed.
It doesn't matter which automation controller you use VLISP, VBA, Delphi,
VB, C++, etc. Each one will show you the Explode method exists for
minserted block objects and each one will return an exception when that
method is called.
You can code around the exception using vl-catch-all-apply.
(setq im (vlax-ename->vla-object (car (entsel))))
(if (vlax-method-applicable-p im 'Explode)
(progn
(setq retval (vl-catch-all-apply 'vlax-invoke-method (list im
'Explode)))
(if (vl-catch-all-error-p retval)
(list "Explode" im (vl-catch-all-error-message retval))))
The documentation should point out that Explode does not apply for this
object. I don't know if the documentation has been updated in 2002 but I
can tell you that the minsert object still exposes an explode method and
still returns an exception if that method is called.
Steve Mighetto
news:5312FF67E7C4C8DBA9F78B38D1606375@in.WebX.maYIadrTaRb...
> return 1.#INF,
> representation of
> Reinaldo
should
> of
when
> > Bobby C. Jones
> > > behavior.
Message 9 of 10
What you can do is copy the appropiate information from the minsert and erase it and array the blocks to match the minsert. We used to copy electrical lighting arrays to minsert to reduce the size of drawings. Arrays have their use I guess but being able to copy them for a minsert and then being able to convert them back into a array is really usefull.
Dave Alexander
Message 10 of 10
salukowski
Use the block editor, copy to clipboard with a base point, open new drawing, paste to original coordinates.  The new file will not have the minsert and acts just a normal cad file.  No need for hacking.  This works in Autocad 2013; I don't know about earlier versions.  I hope this helps.
”Boost
