Visual LISP, AutoLISP and General Customization
explode last
5 REPLIES 5
GeryKnee
602 Views, 5 Replies
explode last
where is the error in code :::
(defun c:PasteBlockX ()
   (command "_pasteblock" (getvar "viewctr"))
   (entdel (entlast))
   (princ)
   (command "-insert" "" "_rotate" 0)
   (princ)
   (command "explode" "last" "")
   (princ)
 (princ)
ommand "explode" does not explode last inserted block
5 REPLIES 5
hmsilva
in reply to: GeryKnee
You'll need to supply a valid point to the INSERT command...
   (entdel (entlast))
   (command "-insert" "" (getvar "viewctr") "" "" "")
   (command "explode" "last")
 (princ)
HTH
Henrique
GeryKnee
in reply to: hmsilva
hello Henrique
I need a code to paste clipboard drawing data , with user specification of insertion point and opposite corner
code
   (entdel (entlast))
   (princ)
   (princ)
 (princ)
works perfectly :::
after copying drawing to clipboard :
Command: _PasteBlockX _pasteblock Specify insertion point:
Command: -insert Enter block name or [?] <A$C6CEC1C74>: Specify insertion point
or [Basepoint/Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: _rotate Specify
rotation angle: 0 Specify insertion point or
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:
Command:
After the end of code execution , there has been created a block (the A$C6CEC1C74 block) that i want to be exploded immediatelly.
Gery
hmsilva
Gery,
if it works for you, perhaps something like this
  (entdel (entlast))
  (while (> (getvar 'cmdactive) 0)
    (command pause)
  );; while
  (princ)
HTH
Henrique
GeryKnee
thanks Henrique
Gery
hmsilva
You're welcome, Gery
Glad I could help
Henrique
”Boost
