Hi sashk -
Lines, circles and arcs cannot be exploded, as you know. You're right -- unless
those entities are filtered out, they will be 'added to the count' of entities
to be exploded (even though they cannot be exploded).
So simply add them to the list of entity types to filter out:
(setq safetypes (list "DIMENSION" "HATCH" "LINE" "CIRCLE" "ARC"))
and they won't be counted among the entities to be exploded. Same results,
different count.
-doug
by the way, when I call you sashk, I somehow don't
think that's your name... care to enlighten me?
"sashk" wrote in message
news:16772763.1088463619828.JavaMail.javamailuser@localhost...
> I noticed one more thing that I tried to get to work....
> When I select things like lines, circles, arcs, etc., it still says that they
exploded them. I tried to make it filter those things out like how the normal
explode command would do, but I messed up. Is there a way when those types of
objects are selected, it will filter them out???
> Thanks so much for all of your help. This routine is great. It helps to
prevent accidental mistakes
