Visual LISP, AutoLISP and General Customization
Executing a command if findfile returns NIL
3 REPLIES 3
The_Caddie
1953 Views, 3 Replies
Im having a little trouble of late understanding how to undertake an action/ command if nil
what i do know id the following:
(setq TESTvar(findfile "acad.lsp"))
(alert TESTvar)
  this gives me the path of the acad.lsp, that is provided it actualy exists, however because the acad.lsp is not compulsary  it may indeed not exist meneaning that the command prompt would return the NIL value instead of the pathname.
based upon that I would like to create a new acad.lsp file if not found by autocad.
however I cant figure this out?
3 REPLIES 3
in reply to: The_Caddie
If that fails then testvar will be nil, as in nothing. so then we can say.
(setq TESTvar (findfile "acad.lsp"))
(if testvar
(dothis) ; if testvar is anything other than nil (in this case the filepath) (dothis) ; if testvar is nothing. );end if
Like you mentioned you don't want to assume the file always exists, so we use "if"  so that when it does not exist then the error will be avoided. and you can have the program do something else instead of fail.
Kent1Cooper
(alert TESTvar)
  this gives me the path of the acad.lsp, that is provided it actualy exists, however ... it may indeed not exist meneaning that the command prompt would return the NIL value instead of the pathname.
If you want to just notify the User one way or the other, and let them handle the creating of the acad.lsp file if needed, here's an arrangement that needs only one (alert) function coded, by nesting the test inside it:
(alert
  (if (setq TESTvar (findfile "acad.lsp"))
    TESTvar ; then
    "Did not find acad.lsp file." ; else
  ); if
); alert
Or if you don't need TESTvar saved as a variable for any other use, but are using it only for notification purposes, you can do without it:
(alert
  (cond
    ((findfile "acad.lsp"))
    ("Did not find acad.lsp file.")
  ); cond
); alert
But if you want the code itself to actually do the creating of an acad.lsp file if it doesn't exist, you can do something like this:
  (alert TESTvar); then
  (progn ; else
    ( ... do stuff with (open) and (write-line) and )
    (  (close) functions, etc., to create the file ... )
  ); progn
); if
Kent Cooper, AIA
hmsilva
The_Caddie,
just one more approach, if you have a backup of the acad.lsp, or other customization files, in a network directory,
you can use "vl-file-copy" to copy, instead you create a new one.
(if (findfile "acad.lsp")
      (alert (strcat "acad.lsp exists in:\n" (findfile "acad.lsp")))
  (progn
    (setq mydir (findfile "acad.mnr"))
    (setq mydir (vl-string-right-trim "acad.mnr" mydir))
    (setq myfile "g:\\acad\\backup\\acad.lsp"); your network directory
    (vl-file-copy myfile (strcat dir (vl-string-left-trim "g:\\acad\\backup\\" myfile)))
    (alert (strcat "acad.lsp was copied to:\n" dir (vl-string-left-trim "g:\\acad\\backup" myfile)))
hope that helps
Henrique
”Boost
