250 Views, 5 Replies
ESC key
Hi
My following routine creates a dimension on the correct layer and restores the previous layer. If some hits ESC before the command is complete it will not restore the previous layer. Is there anything i can do to make sure the previous layer is restored even if the user hits the ESC key?
(defun c:DL ()
(setq lay (getvar "clayer"))
(setq sc (itoa (getvar "useri1")))
(setq ds (strcat "DyerDim" sc))
(setq layname (strcat "05-Dim" sc))
(command "layer" "make" layname "color" "2" "" "")
(Command "-dimstyle" "restore" ds)
(Command "dimlinear")
(while (< 0 (getvar "cmdactive"))
(command pause)
(setvar "clayer" lay)
(setq dim (strcat "Dimension created using " ds " with layer " layname))
(prompt dim)
(princ)
5 REPLIES 5
mdhutchinson
create an error.lsp file and load it from any of the commonly used files... acad.lsp, acaddoc.lsp or Enterprise.mnl file.
in the body of the error routine include something like this - (copied straight from our error.lsp file):
[code]
(foreach val (list "$dynmode" "$sdi" "$clayer" "$osmode" "$dimzin" "$attreq" "$attdia" "$cmddia" "$pickstyle"
"$highlight" "$orthomode" "$autosnap" "$modemacro")
(if (and (getvar (substr val 2)) ; added 2007 support, not a legal var don't run this
(eval (read val)) ; if user pref has been saved
(progn
(setvar (substr val 2) (eval (read val))) ; reset the var to user pref
(set (read val) nil) ; set the variable equal to nil
[/code]
I use this $setvar format for all the variables that I wish to restore to user's preference.
you can find the standard error routine in the online help.
Thanks, i'll give it a go.
You need an error handler, preferably one which is specific to your purposes. In this case, it doesn't need to do a thing in the world but restore your saved "lay" variable.
This has been discused in detail dozens of times, and many examples have been posted.
A very simple form would be:
(defun c:DL (/ *error* lay sc ds layname )
(defun *error* (msg)
(princ))
(command pause)
(prompt dim)
(*error* nil)
Note that all of your variables should be declared local as shown.
Very simple, thanks.
Hope it works out for you.
Another common scenario, besides clayer, is a routine that changes osmode temporarily. The same approach would apply there.
”Boost
