So when I open a drawing a get this error everytime and have to escape a few times to get by it. Hopefully someone can tell me what to delete to stop it from happening I assume it is some lisp routine but can't figure out which to remove. I don't need it to create layers or anyting I just want it to stop hahahaha
Command:
AutoCAD bonus utilities loaded.
; error: bad argument type: numberp: nil
; error: syntax error
C:ASCPOINT loaded. Start command with ASCPOINT.
AutoShade Commands Loaded, errors:
Attribute Rotator
Attribute Text Width Editor
Error: malformed string on input
Set Break Distance = *Cancel*
Error: Function cancelled
AutoCAD Bonus Layer Tools Loaded.
BURST loaded, Type BURST to explode blocked attributes into Dtext
entitiesError: bad character read (octal): 3
CLIPIT
With CLIPIT you can use ARCS, CIRCLES or POLYLINES
to define "clipping boundaries" for BLOCKS, XREFS,
IMAGES and WIPEOUTS.
C:COUNT loaded. Start command with COUNT.
C:CROSSREF loaded. Start command with CROSSREF.
Initial load, please wait... DDMODIFY loaded. Load by typing DNOTE
Please wait- loading.....
C:DOOR and C:DDOOR loaded. Type DOOR or DDOOR to begin.layer
Current layer: "0"
Enter an option
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Fre
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: n
Enter name list for new layer(s): base Enter an option
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: c
New color [Truecolor/COlorbook] : 7
Enter name list of layer(s) for color 7 (white) <0>: base Enter an option
Enter name list for new layer(s): eetext Enter an option
New color [Truecolor/COlorbook] : 4
Enter name list of layer(s) for color 4 (cyan) <0>: eetext Enter an option
Enter name list for new layer(s): eeheater Enter an option
New color [Truecolor/COlorbook] : 2
Enter name list of layer(s) for color 2 (yellow) <0>: eeheater Enter an option
Enter name list for new layer(s): eehtrtag Enter an option
Enter name list of layer(s) for color 2 (yellow) <0>: eehtrtag Enter an option
Enter name list for new layer(s): eepanels Enter an option
Enter name list of layer(s) for color 2 (yellow) <0>: eepanels Enter an option
Enter name list for new layer(s): eenotes Enter an option
Enter name list of layer(s) for color 4 (cyan) <0>: eenotes Enter an option
Command:
Command: layer
Current layer: "0"
Enter an option
Layer "base" already exists.
Enter an option
Enter name list for new layer(s): eeequip Enter an option
Enter name list of layer(s) for color 2 (yellow) <0>: eeequip Enter an option
Layer "eetext" already exists.
Enter an option
Layer "eenotes" already exists.
Enter an option
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: Enter an option
Updating File Stamp...undo
Invalid option keyword.
; error: An error has occurred inside the *error* functiontoo many arguments
Enter an option
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: EXCHPROP loaded.
"EXTRIM" loaded.FIND Loaded. Find and Replace DText Strings. FINDHELP for Help
GATTE loaded.layer
Enter an option
GETSEL.LSP loaded, type GETSEL to place items in the active selection set.;
layer
Enter an option
"LMAN" loaded.
error: malformed list on input
Type MESSAGE to start programlayer
error: Function cancelledEnter an option
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: layer
"MSTRETCH" loaded.layer
error: malformed string on input DDMODIFY loaded. layer
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: REVCLOUD loaded. Type
REVCLOUD to draw Revision Cloud,
to close, return to starting point. For additional Help - RCHELP
File loaded. Enter 'EXP' to use.STYLE
error: LOAD failed: "B:START"
error: extra right paren on inputlayer
TEXTFIT loaded. Type TEXTFIT to stretch/shrink text between points
Type TFHELP for help
error: syntax error
error: syntax error
error: syntax error
C:XDATA loaded. Enter XDATA and XDLIST to define and list data.
XLIST.LSP loaded. Enter "xlist" or "-xlist" to use.
C:XPlode loaded.Enter an option
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: *Cancel*
Open Autocad then type appload -> contents -> Then select the routine that you want to stop being loadded everytime
cad opens .
And this might help you .
Good Luck .
Tharwat
WIsh it did thats the weird thing there is nothing in the startup suite.
I can't even get mditabs to stay there have to load it each time
Still get the errors each time and I have to set my profile each time too.
I am using 2011MEP I used to use just AUTOCAD not sure if that could affect this
@JColombe77 wrote:So when I open a drawing a get this error everytime and have to escape a few times to get by it. Hopefully someone can tell me what to delete to stop it from happening I assume it is some lisp routine but can't figure out which to remove. I don't need it to create layers or anyting I just want it to stop hahahaha
; error: bad argument type: numberp: nilC:ASCPOINT loaded. Start command with ASCPOINT.
Those "Whatever loaded" messages look like the result of things being loaded by acad.lsp or acaddoc.lsp, or perhaps some version-specific acadXXXX.lsp, or a .mnl file associated with your menu file. The layer creations are surely being done by the same file(s) as the loadings of routines.
If you can figure which file that is, and open it, at least you could start by looking at whatever is in it/them prior to something like (load "C:ASCPOINT"), which would at least narrow down the probable source(s) of the three error message in the above-quoted excerpt. You will probably need to run down all the things that it loads and does, and compare them to the Command:-line echoing, to find where the problems lie. If you put semicolons at the beginnings of lines of code to "comment them out," you can compare the echoing with those functions not being loaded, those layers not being made, etc.
so i DELETED C:ASCPOINT; ac_bonus; among others still same deal without the ascopoint error.
Is there anyway to find out which file it could be?
Maybe unload all lisp's from my cui then reload one at a time to see which one casues the error. Going to take awhile seeings as how there are a lot of lisps.
I don't use half of them
Wild Guess: Did you try to create a new profile?
@JColombe77 wrote:so i DELETED C:ASCPOINT; ac_bonus; among others still same deal without the ascopoint error.
I would guess that it is not ASCPOINT that's causing errors, because it looks like that's loading normally. It would need to be something (or some things) that is (are) loaded before that, causing those error message that come before its loaded message. And similarly, the error message afterwards are probably from other things, some of which may be loading problems, and some of which may be just direct functions within the file that's also loading stuff from other files.
Search the Support File Search Path location(s) listed in the Files tab of Options, for files with names like those listed in my earlier reply. Presumably you will find some file(s) like those, with some lines in them that look like:
(load "C:ASCPOINT")
(command "_.layer" "n" .....
I have my lisp folders referenced in support files. But no single .lsp files just folders containing tons of lisp routines
@JColombe77 wrote:I have my lisp folders referenced in support files. But no single .lsp files just folders containing tons of lisp routines
But only those that are run automatically whenever you start AutoCAD or open a drawing or load a menu file are worth looking at, initially. They're the ones with names like acaddoc.lsp, acad.lsp, acadXXXX.lsp, or YourMenuFileName.mnl. They're the ones that might be loading other routines, and they'll be doing it in a particular order, so you can compare their sequence with the messages you're getting, and presumably find what files they're loading at the points where errors are reported. That should narrow down the "tons" to a manageable number. You can then load those independently to see whether you get the same errors, and if so, look into those files in more depth. Or, if they're things you don't use, remove the lines that load those from the automatically-run files.
That's not to say that your 2011MEP might not be causing the troubles, or some of them. Whatever it may be doing could well be inaccessible to you. But looking for those other possible sources could eliminate many other possibilities, and if nothing turns up there, perhaps at least narrow it down to MEP as the likely culprit.
