Error when try to run SAVEASR14
4 REPLIES 4
282 Views, 4 Replies
I downloaded this LISP program that enables you to convert 2000 files
into R14 format. However, whenever I attempt to execute the command
SAVEASR14, I get the following error message:
;error- an error has occurred inside the *error* functionAutoCAD
variable setting rejected: "SNAPBASE" nil
Does anyone have any idea what this means?
Ben Liu
4 REPLIES 4
type this at the command line to see if it works...
(setq fdia (getvar "filedia"))
(setvar "filedia" 0)
saveas
r14
after you are done type this...
(setvar "filedia" fdia)
tell us if that works.. is so the lisp is bad....
A2Ki, SurvCad CES, Win98 se
Remove NO SPAM from my email address to email
Jonathan J. Baker
R&R Engineers-Surveyors, Inc.
Denver, Colorado
_________________________
"Ben Liu" wrote in message
news:3BBDDCC7.1470D563@cadversion.com...
> Ben Liu
Somewhere in the code, there is a (setvar "SnapBase" ...) that is either
using a variable that is nil, or some value other than a 2 atom list of
'REALs or 'INTs.
R. Robert Bell, MCSE
http://www.acadx.com
| Ben Liu
I ran a search on the text in the SAVEASR14.LSP file, and could not find any
occurences of "snapbase". Are there any other ways of locating the source of
the problem?
Ben Liu
> 'REALs or 'INTs.
> | Ben Liu
The error is in the error handler...
news:3BC24CC0.6871FEAD@cadversion.com...
any
of
| the problem?
| Ben Liu
| > 'REALs or 'INTs.
| > | Ben Liu
”Boost
