Hi Robert,
There is hardly anything that actually runs. This is just loading my suite of
various assorted lisp routines in acaddoc.lsp. It's a big file full of gunk.
The only layer related commands I have simply use the "command" function,
"layer method" sounds like something more than lisp. Is there a way to tell
what it is breaking on? In vlide, if I use the last break source, it says
;CALLBACK-ENTRY which I don't understand. I suppose it must be some arx file
or something trying to write to some kind of library that's placed on a
particular layer somehow???
"R. Robert Bell" wrote:
> W/o the code, it's hard to tell, but I would assume that you are using a
> layer method that fails on locked layers.
> R. Robert Bell, MCSE
> http://www.acadx.com
> "Paul Furman"
wrote in message
> news:3BDEFDFC.4185057F@edgehill.net...
> | I'm getting this error while attempting to load my acaddoc.lsp:
> | ; error: Automation Error. On locked layer
> | There are indeed some locked layers, if I unlock all, everything is
> | fine. Unlocking the current layer, layer zero & defpoints doesn't help.
> | Running vlide in animated debug mode doesn't help identify what exactly
> | is causing this.
> | Any ideas?
