You'll have to obtain a selection set of dimensions
with SSGET then step through the block definition
of each dimension to access the mtext entity.
Be aware that if you have used the \X modifier and
the text is in the home position there will be 2 mtext
entities, as opposed to a single entity when away
from the home position.
Autodesk Discussion Group Facilitator
wrote in message news:5152389@discussion.autodesk.com...
I select mtext in dims using nentsel:
(setq ne (nentsel "Select object: "))
(setq en (car ne))
(setq eg (entget en))
Below, I selected mtext from dim:
Command: (setq ne (nentsel "Select object: "))
Select object: ( (-62.8437 110.905 0.0) ((1.0
0.0 0.0)
(0.0 1.0 0.0) (0.0 0.0 1.0) (0.0 0.0 0.0)) ())
Command: (setq en (car ne))
Command: (setq eg (entget en))
((-1 . ) (0 . "MTEXT") (330 .
40093530>)
(5 . "3A32") (100 . "AcDbEntity") (67 . 0) (8 . "COTA") (62 . 2)
(100 .
"AcDbMText") (10 -63.6542 109.773 0.0) (40 . 2.0) (41 . 0.0) (71 . 5)
(72 . 1)
(1 . "\\A1;24.3°") (7 . "ROMANS") (210 0.0 0.0 1.0) (11 0.47695 -
0.87893 0.0)
(42 . 7.39304) (43 . 2.0) (50 . 5.20957) (73 . 1) (44 . 1.0))
Please, exists a way to select the same mtext using ssget command, but
similar to nentsel?
thanks in advance,
Rogerio
