Greetings,
I have written this function to get the Values of 2 specific attiributes in a block and put the values of those attributes in another block.
Everything works fine when I choose a block with those specific attributes. If I choose a block that does not have those attributes, I want to display the message "One or Both of the Part Number attributes not found in part block", instead the function just picks the attributes of a different block in the drawing and uses those.
There are 3 blocks in the drawing that have the invisible attributes that I want to find in the block and one block called FAKE that does not.
I have not been able to find my stupidity, hopefully someone can help me out here.
I have attached a drawing and BOMxfr20.lsp.
Solved by hmsilva. Go to Solution.
Henrique,
Your modifications have fixed the world! Thanks for taking the time to look it over.
Doug
